69 disk brake holdoff valve - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-01-2016, 11:10 AM Thread Starter
i am trying to bleed the new front brakes system on my 69, from booster to caliper and i cant get fluid past the disk holdoff valve, i see it at the input side but cant get it past the valve.
the button on the back of valve doesn't seem to move at all, how much pressure should it take to engage this button on the valve? I have found very little informaion on this valve or its operation.
any tricks to evacuating all the air since all the lines and calipers are new up front? i have a small vacuum type bleeder kit,
thx
Shadetree Racing is offline
post #2 of 4 (permalink) Old 06-01-2016, 06:09 PM
Quoted: 390 Post(s)
Take a look at this photo. The Holdoff Valve is at the upper left. The brass block on the left is the Brake Proportioning Valve. Click here: OE Style Distribution Blocks, Hold Off Valves & Brake Tees.
I think you are talking about the Brake Proportioning Valve? Personally, if either were original to my car, for the price of a new replacement I'd simply install a new one and go from there. Dirt, crud, corrosion, etc. could easily create a problem.
Let us know what valve you are referring to and additional info should follow as to a few things that you might try.
PontiacJim is online now
post #3 of 4 (permalink) Old 06-01-2016, 06:57 PM Thread Starter
everything is new...The brass block on the right is the proportioning valve, the small brass item to the left is a Tee and the "ball like" valve on the left is the hold-off valve. i have installed a new hold off valve as well as the proportioning valve (installed on frame below booster).
i am referring to the roundish hold-off valve that mounts under the master cylinder on the 69.
post #4 of 4 (permalink) Old 06-03-2016, 09:46 PM
Quoted: 390 Post(s)
OK, thanks for confirming the valve in question. I do not have any experience on this, but did a little web research. It may be that your hold off valve is defective. Check out this blog as it seems to be similar to your situation: Can't get fluid past rear hold off - Chevelle Tech
Hope that gives you some ideas to consider.
Disk Brake Component Finish Colorado67GTO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 03-22-2015 09:59 PM
66 lemans disk brake ?'s 66ohc 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 11-09-2012 07:40 AM
front disk brake conversion: alternate cars? yousaygo 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 7 06-07-2010 10:11 PM
Shopping for front disk brake kit. JoeKramer 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 02-14-2007 12:06 PM
front disk brake rotor question matt68gto 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 02-09-2007 08:03 AM
