69 GTO brake issues - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-24-2016, 03:24 PM Thread Starter
69 GTO brake issues
Took a look at some post some issues are simmar thought i would ask
My brake light will come on when I'm stopped at a light for push them hard when driving to stop . If I'm at a light and I lift off the brake just a bit the light will go away .
When I got one I opened the MC cap and noticed my rear chamber was empty ( disc front drums back ) I got Delco brake fluid from my GM dealer filled it up as I was flying up to work I did not have time to bleed the lines but the brakes were much better when I added the brake fluid . However light still Comes on .
I have checked under the car there is no fluid on my garage floor .
Possible it is filling up the booster pump ?
I will Bleed the lines as soon as in home but if that doesn't work does it sound like I'm in need of a new MC and booster?
Thanks guy cheers !
Lawson is offline
post #2 of 2 (permalink) Old 05-24-2016, 04:48 PM
Probably coming from the proportioning valve. Bleed the brakes that should do it. If not I have had to stomp hard on the brake peddle a few times to get the valve to reset or recenter itself. If that works, bleed the system again just in case any air was trapped in the valve.
1965 GTO Brake issues kanthonyk 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 12 02-26-2016 08:28 PM
Brake Light Electrical Issues jtwoods4 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 5 11-29-2013 03:46 PM
Brake Booster/Vacuum Line Issues, 67 Tempest DanT 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 5 07-19-2013 08:20 AM
more brake issues Gremlin66 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 01-19-2010 09:46 PM
Brake Booster Check Valve Issues rushhour Service, Maintenance and Technical Discussion 0 08-06-2005 09:10 PM
