Brake conversion on a ‘65 - Pontiac GTO Forum
post #1 of 2 (permalink) Old 10-20-2018, 03:05 PM Thread Starter
Beware, new GTO owner...
I want to convert to power disc brakes. I'd like to go with larger rotors which means larger wheels. Complete swap will have to wait until I can afford all of the parts.
For now, can I swap in power brake booster and new master and get rid of the single reservoir and do the rest later?
A-Aron is offline
post #2 of 2 (permalink) Old 10-21-2018, 09:18 AM
Quoted: 155 Post(s)
The brake booster will be setup for discs or drums, so you'll likely need to install all at once.
I went with essentially a C5 corvette setup on my 65'. I'd suggest looking at CPP (Classic Performance Parts) for the big brake options. If you get anything close to a 13" rotor you will need 17"+ wheels.
So as advised to me - decide the brakes you want and then select wheels. If you already have the wheels you like, then select brakes that will fit.
FWIW, my brakes are amazing and the car feels like a different beast.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
Front Disc Brake Conversion on a 65 poocher 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 10-08-2014 08:24 PM
Need help with brake conversion Bensjammin66 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 12-28-2009 09:31 PM
Drum brake conversion daveh70 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 07-17-2009 10:58 AM
Disc brake conversion squeezedgto 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 10-31-2006 04:25 PM
1965 Front Brake COnversion BajaGTO 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 03-11-2006 07:10 AM
