brake proportioning valve - Pontiac GTO Forum
post #1 of 5 (permalink) Old 07-21-2017, 09:44 PM Thread Starter
Quoted: 33 Post(s)
My proportioning valve appears to be malfunctioning and not allowing me to bleed brakes with new master cylinder. Do they make new originals or are they all the aftermarket stuff you need to redo your lines for? This is on a 72.
tjs72goat is offline
post #2 of 5 (permalink) Old 07-21-2017, 10:09 PM
Quoted: 106 Post(s)
Did you prime the master before installing?
Have you cracked the bleeders on the passenger side front and rear and tried to gravity bleed?
Pressure bleed?
Need more info.
Goat Roper is offline
post #3 of 5 (permalink) Old 07-22-2017, 09:22 AM Thread Starter
Quoted: 33 Post(s)
Car had been sitting in body shop for over 20 years. Master was dirty. Sucked out dark fluid. Cleaned and filled. Had some peddle to bleed brakes, but wouldn't bleed. Just a little drip at rear only. Replaced master. Bench bled and filled. Got some dark fluid to start at rear, but no other line. Pulled line off calipers in front and one finally bled through some, but stopped. I think the pro valve got messed up with dirty fluid particles.
post #4 of 5 (permalink) Old 07-22-2017, 10:42 AM
Quoted: 106 Post(s)
Inline Tubes has everything you need.
Pontiac Catalog_Neat
post #5 of 5 (permalink) Old 07-23-2017, 08:03 PM Thread Starter
Quoted: 33 Post(s)
Everything if you want to change lines. I was hoping for an original replacement. Thanks.
69 disk brake holdoff valve Shadetree Racing 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 06-03-2016 09:46 PM
Brake conversion proportioning valve? kenbaustin 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 04-27-2014 06:23 PM
1970 Proportioning valve OrbitOrange 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 03-28-2011 11:35 AM
Electronic Brake Proportioning bergenfelter Service, Maintenance and Technical Discussion 1 12-01-2005 02:40 PM
Brake Booster Check Valve Issues rushhour Service, Maintenance and Technical Discussion 0 08-06-2005 09:10 PM
