control arm seals - Pontiac GTO Forum
post #1 of 14 (permalink) Old 08-13-2012, 05:01 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
control arm seals
Hi gang.
Ya know where the upper control arms go thru the fenders right,,,, and the rectangular seals (mud flap do hickies)....anyway they as you know are stapled on. The new 'seal' goes on from the wheel well side
ok...........I got the old staples out finally , with a bit of inspiration pressed the new ones in loosely........ I took the wheel off and am wondering how to press the rubber thu the dam staples......grrrrrrrrr
Is there some trick to it?
I thought of having Mrs Tk hold something over the head of the staples in the engine compartment.....and me in the wheel well and MAYBE could use a small 1/4 drive socket over the ends of each staple and PUSH!?
There's got to be a better way.
thanks as always
Topkat is offline
post #2 of 14 (permalink) Old 08-13-2012, 06:11 PM
nope, take new seals, match them with the holes on the old seals, make small holes on new seals from old seal pattern. then take new seals and slip them on staples, then bend staples. easier with wheel well off car. or match holes with holes on wheel well. same difference. then install staples.
pontiac is offline
post #3 of 14 (permalink) Old 08-13-2012, 06:31 PM Thread Starter
Topkat's Avatar
there are no old ones
Topkat is offline
post #4 of 14 (permalink) Old 08-13-2012, 08:21 PM
69Goatee's Avatar
Use some cardboard from cereal boxes and make some templates. Put em where you want on the wheelhouse, and mark the holes. Transfer the holes to the rubber, use a very small drill to make the holes.
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
RESTORATION IN 1980...
NIN
69Goatee is offline
post #5 of 14 (permalink) Old 08-14-2012, 07:59 AM
I had my inner fenders off the car when I installed the rubber splash shields. Even off I had a difficult time. Installing on the car I have to think is a two person job. To make the holes I used a very small finishing nail chucked into a portable drill. Use a small block of wood as an anvil to drill against. Use the original holes in inner fender, as locating holes. You are only drilling new holes in the rubber. Insert staple, use the wood block to hold down the staple and pair of needle nose on the other side to bend over the two staple legs. Drill and install the staples one a a time. Start in the center and work your way down both sides of the opening. Some one may have found an easier way. Ugly job but it can be done. Good luck..
olde-goat is offline
post #6 of 14 (permalink) Old 08-15-2012, 05:37 AM Thread Starter
Topkat's Avatar
Finally got the drivers side, what a pain.
it does look cool with the hole covered
from the inside its REALLY close the the A arm.
what's the clearence supposed to be if any?
thanks as always
Topkat is offline
post #7 of 14 (permalink) Old 08-15-2012, 09:15 AM
Quoted: 97 Post(s)
No, the pretty much rub. Mine are original on both cars, and kinda tattered. I have no plans on replacing them any time soon. Some folks have used wire in place of the staples, and hav kind of "stitched" them back on....hard to spot, and in an out of the way place. Yeah, it's a "no fun" project, for sure....
post #8 of 14 (permalink) Old 08-15-2012, 04:27 PM
FlambeauHO's Avatar
Quoted: 6 Post(s)
Post pics, want to see how high you guys have em'
FlambeauHO is offline
post #9 of 14 (permalink) Old 02-02-2013, 04:26 PM
Oldeboy's Avatar
Does anyone have any guidance on removing the stapes? I have my fender wells out while I am rebuilding the front suspension. I would like to get the fenders blasted and powdercoated. Thus I need to remove these splash guards.
Thank you.
Oldeboy is offline
post #10 of 14 (permalink) Old 02-02-2013, 10:17 PM
FlambeauHO's Avatar
Quoted: 6 Post(s)
Re: control arm seals
Needle noses or dykes... gently bend them straight and pull em' out... knock old paint lose if you need to.
window seals? firecatsrt 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 03-28-2011 08:31 PM
caliper seals Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 12-13-2010 10:35 PM
68 400 valve seals? Indy1K 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 01-08-2009 12:31 PM
AC radiator seals blondie67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 09-10-2008 02:11 PM
Leaky seals purplehaze Service, Maintenance and Technical Discussion 2 01-01-2007 02:48 PM
