control arm seals - Page 2 - Pontiac GTO Forum
post #11 of 14 (permalink) Old 02-03-2013, 02:14 AM
kilkm68's Avatar
You guys have more patients than me. After about 15 min of trying to get the staples in I just attached them with little sheet metal screws painted black. Looks better than the staples anyway I think. Such little details never bothered me, but I guess if you want a correct restoration, such things matter.
kilkm68 is offline
post #12 of 14 (permalink) Old 02-03-2013, 11:40 AM
I put the shields where I wanted them (and marked them) and used a large needle to poke through. Then when I pulled the needle back, I sat a light colored felt tip on the tip of the needle and made a little dot where the holes wanted to be. Found the holes with the staples, and shoved them through. After you get a couple staples in, then you don't need to mark them anymore- just follow the needle with the staple and push them in with needle nose pliers, and bend them over. Didn't seem terrible, once you got a rhythm going. Easy as pi.
gjones is offline
post #13 of 14 (permalink) Old 04-19-2019, 02:43 PM
integrity6987's Avatar
Quoted: 41 Post(s)
Splash Seals
AMES Cat G34 page 263.
http://www.amesperf.com/catalogs/G34.pdf
Anyone willing to post pictures of how the complex die cut piece (P/N B165B) is installed?
I called Ames but they don't have any figure or anything to reference.
DK
integrity6987 is online now
post #14 of 14 (permalink) Old 04-25-2019, 01:20 PM
Quoted: 41 Post(s)
bump - ANYBODY?
1968 or 1969 preferred. Could probably figure it out from 70-72 also.
Thanks!
DK
window seals? firecatsrt 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 03-28-2011 08:31 PM
caliper seals Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 12-13-2010 10:35 PM
68 400 valve seals? Indy1K 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 01-08-2009 12:31 PM
AC radiator seals blondie67 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 09-10-2008 02:11 PM
Leaky seals purplehaze Service, Maintenance and Technical Discussion 2 01-01-2007 02:48 PM
