correcting for bump steer - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-01-2018, 09:00 AM Thread Starter
I have a 70 GTO Judge that has excessive bump steering issues. Does someone have a means to correct this OR can someone recommend a shop in the Atlanta area that can help?
truetriplex is online now
post #2 of 3 (permalink) Old 01-02-2018, 08:45 AM
Quoted: 155 Post(s)
Any decent alignment shop / race shop should be able to do this.....
You could call Todd Lamb @ Phone:
404-996-4100
Address:
2630 Northgate Ave
Suite A
Cumming, GA 30041
He should be able to give you the name of a great suspension guy near you. Good luck
Chris
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #3 of 3 (permalink) Old 01-02-2018, 09:52 PM
Have the front spindles been changed to later one piece cast steel GM spindles?
Many folks have "upgraded", LOL, to disc brakes by using 2nd Gen F-body spindles or 80's HD B series spindles & have fought bump steer with these tall spindles.
The easiest way to tell is look at the spindle. If it has a separate bolt on HD die stamped caliper bracket, it has either factory disc brakes or a reproduction of the '69 single piston disc brake setup that was avail through '72 on A-body's.
Need help with finding and correcting a coolant leak Crowbelly 1964-1974 Tempest, Lemans & GTO General Discussion 9 05-30-2015 03:59 PM
Bump stick KyleGT05usmc Engine Discussions 12 04-03-2010 11:50 AM
Power Steer Bracket Help zzomby 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 10-04-2009 05:43 PM
Bump shifting? GoatPwr 2004-2006 GTO General Discussion 9 08-13-2008 01:26 PM
new Speed bump Aramz06 Audio & Video Clips 4 06-11-2008 04:23 PM
