Disc brake conversion - Pontiac GTO Forum
post #1 of 4 (permalink) Old 10-24-2006, 09:45 AM Thread Starter
Hello everyone im new to the GTO forum. I was wondering if anyone can help me. I have a 68 tempest that is being semi-cloned. I was wondering if anyone knows what other vehicle disc brake set ups will work on this vehicle (front). The car has power drums now. I have access to a few 80's g-body gm's and wondered if they would work. Thanks
squeezedgto is offline
post #2 of 4 (permalink) Old 10-27-2006, 08:07 PM
Quoted: 4 Post(s)
I would recommend going with the 70-81 Firebird or Camaro spindles if you can find them. There was a company called HO Racing in California that sold a kit in the past. There might be some literature on-line if you do a search. Not only did you get better brakes, but this helps the handling tremendously. I heard a story somewhere that 77-90 full sized chevy's (and some earlier BOP's) might work as well and possibly more common in a junkyard, but have not researched that.
67goat is offline
post #3 of 4 (permalink) Old 10-30-2006, 09:35 AM Thread Starter
Thanks I will check that out!
post #4 of 4 (permalink) Old 10-31-2006, 05:25 PM
Ragtop70's Avatar
www.ecihotrodbrakes.com has a kit that bolts to the stock drum brake spindles. Going to a different spindle may change ride height, alignment and track so measure carefully if using salvage yard parts.
Ragtop70 is offline
