Drum Brakes Locking On All 4 Wheels - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-25-2016, 11:16 AM Thread Starter
Hi, I have a 1967 gto, 4 wheel power drum brakes. New master cylinder, pads and freshly bled. Went for a ride today, got gas and went to leave and I could feel a lot of drag like somebody was pulling on my bumper. The brake pedal was super hard to push, I got maybe a 1/4 inch before I could depress it no further.
I Hobbled home and all 4 Wheels were smoking by the time I got to my garage. I waited 10 minutes for it to cool off and then they worked fine.
What could cause this ?
TonysGoat is offline
post #2 of 3 (permalink) Old 06-25-2016, 03:15 PM
Lemans guy's Avatar
Quoted: 69 Post(s)
sounds like your brakes were locked on by either hydraulic pressure, the power booster or the adjustment on the brake pedal rod.
that rod goes from the pedal through the firewall and into the power booster. Look under the dash, you may see where there is an adjustment nut. also Master cylinder could be the wrong one and when you bolt it to the booster, it is sticking out too far and deploying the hydraulics...so in other words just bolting it to booster pushes MC in and brakes deploy....
they do that and not hard to get the wrong one, small size difference there matters...
Lemans guy is online now
post #3 of 3 (permalink) Old 06-25-2016, 04:39 PM Thread Starter
Thanks LeMans guy. I bought MC off of EBay trying to save a few bucks, looks like right one to me and the info said it was correct. The thing I don't get is why it only happens when it gets hot? Either way, I will order a new one off of Ames and see if it makes a difference.
I was on my way to my 1st car show with it too, figures....
Conversion of Drum Brakes Twwtuna 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 7 09-20-2015 06:13 PM
Front drum brakes or new disc brakes JTS GTO 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 14 01-23-2015 07:13 PM
Drum to Disc Brakes rbkagey 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 11-25-2014 02:37 PM
drum brakes 67goat56 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 10-20-2010 09:50 AM
Need help with drum brakes chainboy1 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 01-04-2010 09:29 PM
