Engine mount problem - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-04-2018, 06:22 AM Thread Starter
I am restoring a 1971 GTO, 400, automatic. The problem is that the headers (Dougs) are touching the frame on the drivers side. Anyone know of a little higher motor mount that will fix this?
Hjudge49 is offline
post #2 of 3 (permalink) Old 05-04-2018, 10:30 PM
Welcome to the wonderful world of headers. You don't want to mess with raising the engine because that will mess up your driveshaft alignment unless you also raise the transmission rear mount by exactly the same amount --- and you may not be able to do that because of clearance to the transmission tunnel. The 'usual' way of dealing with header problems like the ones you're having is to dimple the header tubes with a BFH (big friendly hammer) to get clearance. It makes them look bad, but amazingly enough it usually has no effect on how well the headers work. The Hot Rod Engine Masters guys actually tested that to the extreme and were surprised by the results they got.
Here's a link:
post #3 of 3 (permalink) Old 05-08-2018, 07:56 PM
Quoted: 33 Post(s)
That's actually funny Bear! Loved the pic and am sure the article tells all.
tjs72goat is offline
455 Engine Mount Question bnreed3 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 07-14-2016 06:04 PM
Engine mount holes mysons69 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 07-08-2013 09:18 AM
Engine and Transmission mount help mysons69 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 6 06-12-2013 03:48 PM
Engine Stand Mount Hardware Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 5 12-22-2011 11:37 AM
Engine problem?!? New2thefamily Service, Maintenance and Technical Discussion 4 12-30-2009 01:30 AM
