exhaust hanger kit - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-19-2017, 02:04 AM Thread Starter
ERIC60's Avatar
Quoted: 4 Post(s)
exhaust hanger kit
I'll fit soon brand new mufflers on my 65 GTO;
does anybody have a picture which shows how the hangers are fitted, on muffler and tail pipes?
my actual fitting is a kind of McGyver mess!
Name:	GM A body hanger.JPG
ERIC60 is offline
post #2 of 5 (permalink) Old 08-19-2017, 09:16 AM
the top brackets mount behind the mufflers they mount to the edge of the frame crossmember with two bolts. the small brackets mount alongside of the rear frame rails with one bolt, the thin style clamps are used to attach the tailpipes to the smaller brackets, there are also similar thin style clamps used to mount ornamental tailpipe extensions (tailpipe tips).
post #3 of 5 (permalink) Old 08-19-2017, 09:20 AM Thread Starter
ERIC60's Avatar
Quoted: 4 Post(s)
yes, I had figured out more or less the location, but I don't understand the two rubber bands, one vertical and one horizontal;
ERIC60 is offline
post #4 of 5 (permalink) Old 08-19-2017, 10:11 AM
the rubber mtg flaps follow the contour of the frame crossmember. Each of the mounts is a mirror image of the other, & can only be bolted up one way. I will be back in building in an hour & can look under a car & note if the flat horizontal flap mounts on the inboard side.
post #5 of 5 (permalink) Old 08-19-2017, 10:13 AM Thread Starter
ERIC60's Avatar
Quoted: 4 Post(s)
ok, if you can take a picture , even better;
cheers
ERIC60 is offline
Kooks complete exhaust kit Gunn3r87 Intake and Exhaust Discussions 1 11-16-2014 01:32 AM
side exhaust kit question! travy082 Intake and Exhaust Discussions 6 12-31-2011 11:09 AM
Lost an exhaust hanger hockey499s Intake and Exhaust Discussions 2 06-27-2011 09:28 PM
Exhaust hanger brackets SWGOAT Intake and Exhaust Discussions 1 03-27-2011 02:16 PM
Pics of my car in airport hanger batmans The Lounge 5 08-12-2009 09:55 AM
