Exhaust manifold guestion - Pontiac GTO Forum
post #1 of 6 (permalink) Old 12-20-2018, 01:38 PM Thread Starter
1966 gto. The engine and manifolds were in a 68 firebird. Did I make a mistake with the motor mounts or do I need another drivers side manifold? It’s really close
ID:	116809   Click image for larger version
Ken 66gto is offline
post #2 of 6 (permalink) Old 12-20-2018, 02:22 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
that sure looks like a mid 70's manifold with 3 collector bolts....
you need a set of correct set of std manifolds with 2 bolt flange
or better yet buy a set of HO manifolds for the 64-67
Scott
whats the part number on your exhaust manifolds ?
BLK69JUDGE is offline
post #3 of 6 (permalink) Old 12-20-2018, 03:25 PM
Quoted: 69 Post(s)
If that's the only problem with using those manifolds, looks like you could just grind off enuff of the flange, so that there will be no contact. Looks like you'll still have enuff meat around the hole for it to work.
But, the high dollar manifolds mentioned would be nice, if you can afford 'em.
https://www.ramairrestoration.com/rm...y-headers.html
https://www.ramairrestoration.com/rm...oversized.html
bigD is online now
post #4 of 6 (permalink) Old 12-23-2018, 05:37 PM Thread Starter
Thanks, I think they are mid 70's exhaust manifolds. I hate to say it, but I may go with a set of headers, until I find my "forever engine"
Just wondering how much clearance I would need? How much side to side movement.
Ken
post #5 of 6 (permalink) Old 12-23-2018, 06:24 PM
Quoted: 69 Post(s)
If you decide to go with headers, Hedman #28140 3-tubes might be a good choice, since they will fit so many body styles. Might make 'em easier to sell, when the time comes. Might even be able to find some decent used 3-tubes for a real good price.
https://www.streetsideauto.com/p/hed...saAnPREALw_wcB
Some insist on coated 4-tubes with at least 1 3/4" size tubes, even on mild street only cars. It's your money, so your call.
bigD is online now
post #6 of 6 (permalink) Old 12-23-2018, 06:54 PM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
I would think 1/4" to 3/8 for the torque roll 1/2 is nice
is your forever motor a WS 66 389 or a 455
it would make a difference on where I would spend MY money
Scott
Standard Manifold to Ram Air Manifold exhaust upgrade Lemanster70 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 12 07-30-2016 11:54 AM
Question about a cam/heads/intake guestion. chad.fear Engine Discussions 0 04-02-2011 11:02 PM
Exhaust Manifold - 4 hours and one bolt out! 70455goat Intake and Exhaust Discussions 7 11-25-2007 08:10 PM
70 GTO 455 Exhaust Manifold leak question 70455goat Engine Discussions 2 11-09-2007 02:31 PM
exhaust manifold gaskets, yes or no. Topgoat 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 1 09-30-2006 07:38 AM
