Front coil over spring rate help - Pontiac GTO Forum
post #1 of 6 (permalink) Old 12-23-2018, 04:57 PM Thread Starter
I'm looking to purchase a set of coil overs for my 1966 GTO. The car will not see the track or autocross. Daily driver as a real estate agent car. I like the Qa1 set with 500 lb springs,
My question is.. What spring rates and coil overs are people running?
Ken
Ken 66gto is offline
post #2 of 6 (permalink) Old 12-23-2018, 09:25 PM
Quoted: 390 Post(s)
Ken
In the right hand corner of this page is the "Google Custom Search." Type in "front coil overs" and you will find several recommendations.
post #3 of 6 (permalink) Old 12-24-2018, 08:01 AM Thread Starter
Thanks Jim
Thanks Jim,
Believe it or not I did a search first. Found a few pages you responded to but I didn't find a recommendation from someone who installed and has driven their car. Is a 500 lb spring too hard for a driver 66 GTO
Ken
post #4 of 6 (permalink) Old 12-24-2018, 08:28 AM
Quoted: 155 Post(s)
Thanks Jim,
Ken
I went with 550# springs (Viking double adjustable coilovers) on my 65 convertible and absolutely LOVE the ride. I replace all of the rubber up front as well (with poly). The car is very responsive / predictable and for me the spring rate is appropriate for such a heavy and fast car. Happy to answer any questions you may have. All the best and Merry Christmas!
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #5 of 6 (permalink) Old 12-24-2018, 09:43 AM Thread Starter
100 lbs front end weight difference from 500 to 550
500 rated for a small block - 550 big block according to summit
My current motor is a 350, but the weight should be the same as a 389/400
Big decision, big purchase
post #6 of 6 (permalink) Old 12-24-2018, 08:34 PM
Quoted: 155 Post(s)
The pontiac 389 / 400 is a heavy motor....All the folks I spoke to at UMI / Sphoon / Viking all recommended 550# (but they know how I like to drive too)....My daily driver is a 600+ whp car and I enjoy surprising supercars when out for a spin or just getting groceries. If you like to "cruise", you would be fine with a softer spring (car may roll a bit more in turns and move around more under acceleration / deceleration)....
Good luck
Current setup:
4 speed Muncie
Front coil springs vs. spring compressor-HELP!!! LouCabra 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 13 08-01-2018 10:08 PM
66 gto front coil spring removal and replacement tonyli 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 05-17-2016 08:09 PM
Spring rate rnoswal 2004-2006 GTO General Discussion 5 07-12-2015 07:53 PM
67 Front Coil Spring Compressor cmm47172 1964-1974 Tempest, Lemans & GTO General Discussion 5 07-02-2014 08:41 AM
front coil spring installation Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 10-26-2010 07:54 AM
