front coil springs 1967 GTO - Pontiac GTO Forum
post #1 of 8 (permalink) Old 10-21-2015, 10:38 AM Thread Starter
alanmay0's Avatar
I am looking to replace the front coil springs on my 1967 GTO with air conditioning. It seems like all of the springs I have located on the net, so far, are for the 1967 GTO w/o a/c. So what is the difference between a GTO w/o a/c and one with a/c when it comes to replacing the front coil springs.
Thanks in advance.
alanmay0 is offline
post #2 of 8 (permalink) Old 10-21-2015, 11:59 AM
EATON springs list them as a part #MC3474 .
https://www.eatondetroitspring.com/o.../parts-lookup/
post #3 of 8 (permalink) Old 10-21-2015, 12:03 PM Thread Starter
alanmay0's Avatar
front coils springs
There has got to be a better price than 170.00 for two coil springs. Anyway what is the difference between springs with GTO with a/c and w/o a/c? That is my question.
thanks
alanmay0 is offline
post #4 of 8 (permalink) Old 10-21-2015, 12:48 PM
A/C springs are rated for more weight for the added A/C components.
post #5 of 8 (permalink) Old 10-21-2015, 02:50 PM
Thanks in advance.
same answer as last month,
https://www.gtoforum.com/f50/front-co...-67-gto-94233/
my answer is from the experience of decades of installing and in many cases sourcing correct col springs. Was so glad I stumbled onto CSS. Also have ordered correct coil springs through a friend's early F body shop who for years ordered Eaton springs (mainly leaf springs) on a whls acct. In the early 90's, installed 2 pair of Moog front springs, one on in my old bodymans GS Buick, I always though the GS sat too high.
When it comes to pricing, one can't buy correct spec coil springs for closeout pricing off RockAuto or Amazon. Flip through a few searches of completed "restored" late 60's early 70's GM musclecars on eBay. Ck out the 4x4 stances on the quickly thrown together "restorations" . Generic cheap springs 9 times out of 10, get cheap results.
post #6 of 8 (permalink) Old 10-21-2015, 09:37 PM Thread Starter
alanmay0's Avatar
front coil spring 1967 GTO
Who is CSS?
thanks
alan
alanmay0 is offline
post #7 of 8 (permalink) Old 10-22-2015, 06:36 AM
Coil Spring Specialties
Well trusted source for correct original specification coil springs,
also a source for custom spec lowered coil springs.
post #8 of 8 (permalink) Old 10-29-2015, 03:49 PM
Quoted: 9 Post(s)
My 2 cents
I agree with the difference being the additional weight in the front end from the A/C components. I just replaced the front and rear springs with the correct spec springs (non-a/c) on my '68 and i will say that the front end now sits about 2 inches higher than the rear. My old car guy says that's the way it would have looked new in '68. Looks a bit odd to my eye, but if he's correct, i'm ok with it(?). If you're looking for level or a bit lower in the front with stock springs and shocks in the rear, you might consider a spring drop in the front.
wishihaditback is offline
Front coil springs 67 GTO alanmay0 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 09-19-2015 11:30 AM
Heated Front Coil Springs On '66 Gto take5 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 09-11-2009 10:16 PM
