front disk brake rotor question - Pontiac GTO Forum
post #1 of 2 (permalink) Old 02-07-2007, 08:47 PM Thread Starter
my 68 gto has a two piece front rotor. I assume it is original. I can't find the minimum thickness that the rotor can be. The books only have the one piece rotor listing for minimum thickness. Is it possable that these are after market rotors? Please help.
matt
matt68gto is offline
post #2 of 2 (permalink) Old 02-09-2007, 09:03 AM
anmracing's Avatar
Usually the minimum thickness is stamped on the edge of the rotor. If they are orig then you may need to run some sand paper around the edge to see if you can find the numbers.
For the sweet sound of power,
anmracing is offline
