Front drum brake spring location - Pontiac GTO Forum
post #1 of 8 (permalink) Old 06-14-2019, 06:50 PM Thread Starter
Ohio66GTO's Avatar
Quoted: 14 Post(s)
Looking for some help with the location of all the springs. I made the mistake of pulling them all off without taking pictures or leaving one side together since I have the shop manual. Unfortunately the shop manual doesn’t specify which ones go where. I bought a Dorman brand kit and there are two different size springs that go at the bottom by the adjuster. One is a slightly smaller diameter then the other. Is one for the passenger and one for the driver side? I attached a picture. One is brown and the other is white. If anyone has any pictures that would be helpful. Thanks.
Ohio66GTO is offline
post #2 of 8 (permalink) Old 06-14-2019, 07:06 PM
Quoted: 401 Post(s)
Looks like you may be missing a few parts with that kit. I don't think it is complete.
https://www.gtoforum.com/f50/front-d...diagram-22492/
post #3 of 8 (permalink) Old 06-14-2019, 07:22 PM Thread Starter
Ohio66GTO's Avatar
Quoted: 14 Post(s)
This is everything I got in the kit. I just can’t figure out which springs go into those copper colored pieces. It’s either the blue ones or the green ones. Also I’m not sure if there is a driver/passenger spring between the two at the bottom of the picture since one is smaller then the other. The ones that came off were identical. Any idea if it makes a difference?
post #4 of 8 (permalink) Old 06-15-2019, 09:00 AM
Quoted: 401 Post(s)
Originally Posted by Ohio66GTO View Post
This is everything I got in the kit. I just canít figure out which springs go into those copper colored pieces. Itís either the blue ones or the green ones. Also Iím not sure if there is a driver/passenger spring between the two at the bottom of the picture since one is smaller then the other. The ones that came off were identical. Any idea if it makes a difference?
Don't think it makes a difference. No "left" or "rights." One was made in southern China while the other in norther China. You could also use your old ones if they are still in good shape.
post #5 of 8 (permalink) Old 06-15-2019, 09:44 AM Thread Starter
Ohio66GTO's Avatar
Quoted: 14 Post(s)
Hahaha. Ok. Do you know which hold down spring goes into the adjuster? There are different springs.
post #6 of 8 (permalink) Old 06-15-2019, 10:20 AM
BLK69JUDGE's Avatar
Quoted: 70 Post(s)
BLK69JUDGE is online now
post #7 of 8 (permalink) Old 06-15-2019, 03:31 PM
deanhickey's Avatar
Quoted: 38 Post(s)
Hope this helps
deanhickey is offline
post #8 of 8 (permalink) Old 06-15-2019, 08:39 PM
Quoted: 401 Post(s)
Originally Posted by BLK69JUDGE View Post
Same one I posted earlier??
