Fuel tank help - Pontiac GTO Forum
post #1 of 17 (permalink) Old 02-19-2016, 04:46 PM Thread Starter
Fuel tank help
Hey guys,
Was curious if I could maybe get some insight. Just replaced the entire fuel system, tank, lines, pump, lines to carb. My tank is mounted, but the filler neck is really push up there, nearly impossible to get any nozzle from a gas can in there, the angle from neck with the bumper in the way, no dice. I replaced the carriage bolts with what was on the car in the first place, 3 inch bolts, which may be wrong. I've looked around and can't find the length of them, and wonder if this is my issue. Thanks for you help.
Edit: I'm a DA, it's a 66 tempest.
ID:	72289   Click image for larger version
CptTheAlex is offline
post #2 of 17 (permalink) Old 02-19-2016, 06:32 PM
Wendt69's Avatar
Quoted: 5 Post(s)
You have your straps backwards. I just removed my tank (69 gto) and the long bolts install above the diff.
That may change the angle your tank is sitting at.
Wendt69 is offline
post #3 of 17 (permalink) Old 02-19-2016, 06:40 PM
Wendt69's Avatar
Quoted: 5 Post(s)
Or you have a different year? Almost looks like the neck is bent up?
Wendt69 is offline
post #4 of 17 (permalink) Old 02-20-2016, 07:23 AM Thread Starter
Sorry, totally didn't specify that it's a 66'. I'm pretty sure the straps are in there correctly, I've tried every method to keep the tank angle downward, aside from bending the neck.
post #5 of 17 (permalink) Old 02-20-2016, 08:14 AM
Lemans guy's Avatar
Quoted: 69 Post(s)
Did you put the rubber pad between the gas tank and the trunk floor?....NPD or Ames has them.....the old ones do get compressed quite. Bit...
But those tank take some finesse to get them in right...
Take it out n start again....something is not fitting in the right notch and it looks like your tank might need to go back toward the rear a half inch or inch and lower....
Try again you will get it!
Lemans guy is offline
post #6 of 17 (permalink) Old 02-20-2016, 09:44 AM Thread Starter
No sir, didn't know there were rubber pads that go between. I'll screw with it some more.
I just assume there is really only one way it can go in, that's why I figure maybe my bolts aren't long enough.
post #7 of 17 (permalink) Old 02-23-2016, 06:35 PM
pjw1967's Avatar
Did you ever get this squared away? I put a new stainless tank in my '67 awhile back. Had to use the orig straps as the new stainless straps were too short from being bent wrong. My filler neck was a little closer to the bottom of the trunk but not enough to impede inserting a gas nozzle. I can take some measurements around the neck if you still need some guidance.
GTO Tank by pjw1967 | Photobucket
GTO Tank Vent by pjw1967 | Photobucket
pjw1967 is offline
post #8 of 17 (permalink) Old 02-23-2016, 07:47 PM
Lemans guy's Avatar
Quoted: 69 Post(s)
cpt?..trying to remember back when I put in a new tank and straps last year,...I believe the straps were a real pain and I had to use longer carriage bolts. i did use a new rubber pad under the tank as the old one was gone and Ames, NPD has them. But I remmeber having to fight it to get it to seat right and get it snugged and make sure the neck is at the correct spot. Longer bolts can work, actually it is just that those straps are hard to bend to use up every micro inch of air and get them to lay flat. ....
Pulling for you....I know that you will get it, if you get a bite on a longer bolt you can pull it up tight...
post #9 of 17 (permalink) Old 02-23-2016, 07:54 PM
Is it a new tank?? If so it might be possible to solder the neck in too deep?
post #10 of 17 (permalink) Old 02-23-2016, 10:59 PM Thread Starter
No sir, heading out of town this weekend, so ill get back on it next week. I'll update you as to what happens. I think my bolts are too short in the first place, plus i need to add the rubber straps. I am using the original mounting straps that came with the car, going to try and finesse it a little more.
Fuel Tank Standpipe Icefan71 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 10-29-2012 01:04 PM
grinding around fuel tank area should i remove tank ? fiesta62 1964-1974 Tempest, Lemans & GTO General Discussion 7 11-08-2011 08:12 PM
fuel tank Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 2 07-09-2011 10:26 AM
Stock gas tank to ATl Fuel Cell, Fuel pump,ETC??? cpr Drive train, suspension, alignment and brakes. 1 04-29-2009 09:20 AM
