Gas tank / neck - better design ?? - Pontiac GTO Forum
 2Likes
  • 2 Post By PontiacJim
post #1 of 7 (permalink) Old 01-04-2018, 10:19 AM Thread Starter
Quoted: 155 Post(s)
I have a 65 GTO convertible and I am guessing an incorrect gas tank (please see picture). Filling the car up is a ROYAL PAIN IN THE A$$ as you are bent over pushing the filler into the neck and then have to be very careful as to not pump too fast otherwise the infamous back flow of gas out the neck . Fun fun .
I am curious if folks have implemented a better neck design or relocated the neck to improve fill-ups ? Thanks in advance
Chris
Name:	gas tank neck front.jpg
ID:	101297   Click image for larger version
Name:	gas tank neck side.jpg
ID:	101305   Click image for larger version
Name:	gas tank underside.jpg
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #2 of 7 (permalink) Old 01-04-2018, 05:42 PM
Quoted: 390 Post(s)
Looks about right to me. Welcome to the world of old cars.
integrity6987 and JNYBOY like this.
post #3 of 7 (permalink) Old 01-05-2018, 07:30 AM Thread Starter
Quoted: 155 Post(s)
I am going to replace my tank as it looks old and I believe has a leak on the top side. Any recommendations on replacement tanks?
Here are a few new tanks, any recommendations on fit and application ? :
Tom's Classics : (made in china) 2 3/8" line sending unit, 304 stainless tank https://www.ebay.com/itm/-/331163280070?
Tom's Classics : (made in china) 304 stainless https://www.ebay.com/itm/65-67-GTO-s...m4383.l4275.c1
AM Autosport : https://www.ebay.com/itm/Fuel-Gas-Ta....c100005.m1851
Wholesale Parts : https://www.ebay.com/itm/21-5-Gallon...4383.l4275.c10
The Tom's Classic claims to be 304 stainless (not sure what the originals were), but I am assuming the picture is incorrect as the sending unit location is wrong. (I have a question into the seller.)
Current setup:
4 speed Muncie
post #4 of 7 (permalink) Old 01-05-2018, 10:58 AM
Make sure the filler neck has the correct offset like the originals. If not, the nozzle won't fit into the filler neck. Some of the aftermarket tanks need to be modified to work or get one without the filler neck attached.
GulleyGulley is offline
post #5 of 7 (permalink) Old 01-05-2018, 11:37 AM
Spectra, only the way to go.
Buying locally allows you to examine and confirm no shipping damage.
Prob worth ck'ing with OPGI as they are SoCal market based.
post #6 of 7 (permalink) Old 01-05-2018, 12:01 PM
Quoted: 106 Post(s)
Chris
Hold the vapor recovery snoot back and listen for the gurgle.
Takes practice to stop the back splash.
Goat Roper is offline
post #7 of 7 (permalink) Old 01-06-2018, 07:16 AM Thread Starter
Quoted: 155 Post(s)
Thanks Eric! The combination of the neck and being down low doesn't help. My 56' Bel Air is much easier to fill.
Chris
Current setup:
4 speed Muncie
68 GTO gas tank filler neck? DaveM 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 05-04-2019 02:48 PM
1968 Gas Tank neck removal par4n1 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 5 07-01-2016 01:21 PM
68 Gas Tank dhinnah 1964-1974 Tempest, Lemans & GTO General Discussion 5 12-22-2010 09:12 PM
Aus gas tank vrs USA tank? GO-GTO! Service, Maintenance and Technical Discussion 23 03-03-2006 11:45 PM
