Gas tank removal & sender replacement. - Pontiac GTO Forum
post #1 of 7 (permalink) Old 09-10-2018, 08:07 AM Thread Starter
11th Indian's Avatar
Quoted: 26 Post(s)
Good morning!
I need to replace the fuel level sending unit for my 72 GTO (400)
Are there any surprises and or known issues or things to look out for with dropping the tank and changing out this part?
Thanks !
11th Indian is offline
post #2 of 7 (permalink) Old 09-10-2018, 10:40 AM
Not really. I assume you've already taken a good look at it and see where the fuel line (and the vapor return line if it has one) attach to the tank along with the wire and ground for the sending unit. Gasoline is heavy (6 pounds per gallon) so having the tank as empty as possible is helpful. Plan ahead. When you disconnect the lines they may puke fuel so be ready with a way to plug them quickly both at the line and at the tank. Take the usual precautions when working around gasoline and remember that vapors are heavier than air so they tend to 'crawl' along the floor. Be mindful of any possible ignition sources - water heaters for instance. Once you get it all disconnected and the straps loosened, go slow. You don't want to let the weight 'hang' on the filler neck. Keep your eye out for connections such as vent hoses that you might have missed.
post #3 of 7 (permalink) Old 09-11-2018, 07:37 AM Thread Starter
Quoted: 26 Post(s)
Good stuff, thank you.
Going to do this outside after removing as much gas as possible with a manually operated hand pump. Prepared with extra fuel line assuming the 45 year old lines may be degraded.
post #4 of 7 (permalink) Old 09-11-2018, 10:19 AM
Good move!!! Fire bad....
Every inch of fuel line in my car from front to rear, including the vapor return line, is now either hard-line tubing or braided AN type hose.
Hopefully you're either also going to replace the fuel sock on the inlet side of the pickup, or remove it completely and use a GOOD filter in the line near the tank. These things are known to plug up and they're a pain to replace when they do.
post #5 of 7 (permalink) Old 09-11-2018, 10:30 AM Thread Starter
Quoted: 26 Post(s)
The new sender unit came with a replacement fuel sock.
Going to change out the lines at the pump also. Fire is definitely bad, and a gas fire is about as bad as it can get.
post #6 of 7 (permalink) Old 09-11-2018, 10:39 AM
...Something that, unfortunately and sadly, I'm well aware of.
post #7 of 7 (permalink) Old 09-14-2018, 03:20 PM Thread Starter
Quoted: 26 Post(s)
Done, cake walk!
Used a harbor fright transfer pump to drain the tank, some PB blaster on the bolts holding the straps and replaced some fuel line, maybe 90 minutes including jacking up the car.....
This was gift of a job. Even surprised me. Now I have fuel gauge again!
[IMG][/IMG]
1968 Gas Tank neck removal par4n1 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 5 07-01-2016 01:21 PM
fuel tank sender ground johnnylightning03 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-08-2010 09:27 PM
Gas tank cage removal enjracing 2004-2006 GTO General Discussion 39 06-19-2006 05:54 PM
how can gas tank cage removal be dangerous? enjracing 2004-2006 GTO General Discussion 18 06-15-2006 04:38 PM
Aus gas tank vrs USA tank? GO-GTO! Service, Maintenance and Technical Discussion 23 03-03-2006 11:45 PM
