Purchased headers already without figuring out clearances. They are full length going into 67 GTO with Dearborn 3spd toploader tranny and aftermarket high torque mini starter. Any heads up re this fit as far as oil filter or any other clearance issues. Engine is stock 400 with 670 heads. Thank you for your help.
I stand corrected. Proportioning or distribution block is on a 67 GTO with all wheel drums. It's on the inside of the frame rail right next to where the Hedmans are. Moving that block and rerouting lines from the master cylinder to and from it. The rag joint on the standard steering box also interfers with headers so making clearance there as well. 'Z' bar, starter and oil filter clear np. Will wrap the high torque mini starter anyway.
i had to heavily modify my 1 3/4 hedman header flanges to access the bolts, particularly the bolts between cyl 5-7 and 6-8. these headers were longer than normal. this was on iron heads on a 1965. also clearanced for the rag joint. the brake line from the master cylinder to the distribution block was very close but didn't touch
Related Threads
Pontiac GTO Forum
514K posts
38.4K members
Since 2004
