Hydraulic brake assist kits-opinion? - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-11-2016, 11:05 PM Thread Starter
Anybody have an opinion on replacing my 69 GTO stock master cylinder/booster with a hydraulic brake assist kit like from CPP?
My master booster went out and rather than replace with the same, I am thinking going with the assist kit. I need more room between the valve covers and that huge master booster. But my mechanic advised not to do it because if the power steering goes out...so does the brakes.
Thanks!
Luiz is offline
post #2 of 3 (permalink) Old 04-12-2016, 06:23 PM
Quoted: 390 Post(s)
Thanks!
You want to contact member BearGFR on this one. He has the hydroboost on his radical cammed '69.
My guess would be that if the power steering pump went out or you threw a belt, I would think the brakes will still work, just without the assist - same as power steering when you snap a belt. If the brakes were to go out, I don't think the factory would be putting these on vehicles, let alone the national vehicle safety people wouldn't go for it either.
post #3 of 3 (permalink) Old 05-04-2016, 09:41 PM Thread Starter
Well my mechanic highly advised against hydraulic brake assist. So we went with the standard vacuum albeit an 8" brake booster vs the 12" in stock. 8" gave me more clearance for my valve covers.
Luiz is offline
RightStuff brake kits kjk990 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 26 10-02-2013 01:39 PM
Big Brake Kits tylenoljones Drive train, suspension, alignment and brakes. 8 07-29-2013 03:40 PM
Summit Racing Disc Brake Kits Josh.AZ.GTO 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 5 10-29-2012 04:57 PM
TBYRNE Motorsports is now carrying Wilwood Brake Kits! tbyrne 2004-2006 GTO General Discussion 0 04-27-2005 10:57 AM
