Line lock installation single master cylinder - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-08-2015, 01:24 PM Thread Starter
LINE LOCK INSTALLATION SINGLE MASTER CYLINDER
;Installing hurst line lock on manual brakes, do I need a separate valve installed to allow line lock to apply to front brakes only separating the back brakes? Thanks any info. appreciated!!! If separate valve is needed where can I purchase 1966 GTO manual brake system
ottfive is offline
post #2 of 3 (permalink) Old 09-08-2015, 01:40 PM
Quoted: 4 Post(s)
The line-lock solenoid itself IS the valve. Install it somewhere in the line going to the front brakes, only. When you apply the brakes, then mash and hold the line-lock button, when you release the brake pedal, the fluid pressure to the rear bakes will be released, but the pressure to the front brakes will remain, until you release the line-lock button.
oldskool is offline
post #3 of 3 (permalink) Old 09-08-2015, 02:17 PM Thread Starter
Thanks for the info.,I was told it made a difference if you had a single master cylinder or a dual master to which lines controlled front and rear brakes?
ottfive is offline
Master Cylinder ID Code Red1970GTO 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 11-21-2014 03:54 PM
Clutch Master cylinder johnfin Service, Maintenance and Technical Discussion 1 08-24-2013 03:13 AM
Switch master cylinder Richtenb Drive train, suspension, alignment and brakes. 1 04-15-2010 04:57 AM
master cylinder question 66tempestGT 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 04-12-2010 07:35 AM
