Long cranking after sitting 1 week cure? - Pontiac GTO Forum
 5Likes
post #1 of 43 (permalink) Old 12-02-2018, 09:17 AM Thread Starter
11th Indian's Avatar
Quoted: 26 Post(s)
My 72 cranks for a long time to start after sitting for a week,. I know this is a common issue with the fuel evaporating and the bowls are dry.
Once the car is started - it will re-start hot of cold immediately.... for a few days.... I just dont drive it daily.
I was wondering how does anyone else with this issue deal with it? Do you just crank it a few times for a few seconds?
Small squirt bottle with gas, fill up the bowl first ?
Electric fuel pump?
Thanks!
11th Indian is offline
post #2 of 43 (permalink) Old 12-02-2018, 10:51 AM
Quoted: 9 Post(s)
Same issue with me, though generally longer than a week. I just crank it for 4-5 seconds, then pump the pedal twice and it fires right up
ajluzi1957 is offline
post #3 of 43 (permalink) Old 12-02-2018, 11:29 AM
Quoted: 390 Post(s)
Electric fuel pump?
Thanks!
Electic fuel pump back at the tank seems to be the best solution assuming no cracked rubber lines sucking air, dirty fuel filter, problem with a fuel line, etc..
Ethanol in the gas is the problem. The gas will evaporate when sitting long periods. Common problem. My brother added the electric fuel pump to 2 of his older cars and it solved the issue as well as hot start issues. You don't need a huge killer pump and you want to keep your factory fuel pump to act as a regulator.
If you do a search of th forums you will find other answers/ideas as this has been covered several times.
post #4 of 43 (permalink) Old 12-02-2018, 01:45 PM
Quoted: 66 Post(s)
X2 on the part time electric pusher pump. This works if your accelerator pump will squirt gas. If not, you'll need to pour or squirt a little gas into the primaries, by hand. My last bracket car had a RobbMc mechanical pump, only. So, when cold, I poured in a little gas from a small plastic bottle.
bigD is offline
post #5 of 43 (permalink) Old 12-02-2018, 02:05 PM Thread Starter
Quoted: 26 Post(s)
Thanks guys...
Going to try the squirt bottle with gas first, ifs thats a PIA, then the electric pump near the tank.
On a previous car I had an electric pump and a pre -oiler. Was like having a preflight check list.
post #6 of 43 (permalink) Old 12-04-2018, 11:32 PM
Electric fuel pump?
Install An electric pump, hook it up to your key, if it's sits a while Turin the key on for a few second then crank her up.. ofcourse, you will want a filter before the pump, and use a relay, and perhaps a return line and a regulator.. it don't sound to simple now..
There are pumps that don't require a return line..or regulator but I would use a relay....
1966tempest is offline
post #7 of 43 (permalink) Old 12-05-2018, 12:53 AM
BLK69JUDGE's Avatar
Quoted: 67 Post(s)
I dont know about an electric pump and the mechanical pump hooked up in tandem...
here is my experience ....
1988-89 ..... early summer.... girlfriend has 81 Z-28 with a warmed up 350 th350 t top last of the cool body style...
615 am ,,, her car is under the carport in front of the house and time to go to work.... I am lockin up the house
to leave also ...
I hear her crank it over and BOOOOOOOM !!!!!!! house windows shook ...my horns honkin on my 68 gto alarm is goin off..
sounded like a quarter stick of dyno just went off !!
I whip the front door open and look towards the carport.... I see the neighbor stoner kid flyin out his open bedroom window and rollin into the front yard in his undies .... yellin WTF !!!
my girlfriends sittin in the car with smoke rollin out from under the hood ... by the windshield and fender gaps and under the car
I have to peel her hands off the wheel ....
ran to the kitchen for a fire extinguisher .... as shes just screaming in the front yard with the neighbor
by now his parents are outside as we all left for work around the same time..
I pop the hood ... NO FIRE .. but 1 morroso valve cover is layin on the inner fender totally ripped off the engine
and the other has 2 T bolts
bearly holdin it on .... WTF ???
well the electric pump blew a hole in the diafram in the mechanical pump and pumped fuel into the crank case
with the mallory ignition and sittin overnite and the fumes building up .... it blew the valve covers off when she tried
starting it
timing cover was all swollen and the oil pan too .... had to pull the motor .... swap the m out too
I still have one of the heavy steel wide valve cover bolt spreader bars ,,, on a key chain bent up at a mild V shape
so .............
I dont think I will ever do it ... have both electric and manual together....
but ..............
Scott
just my .02 sense worth
john23 and Stereolab42 like this.
BLK69JUDGE is online now
post #8 of 43 (permalink) Old 12-05-2018, 12:09 PM
BLK69JUDGE fun story, thanks
john23 is online now
post #9 of 43 (permalink) Old 12-05-2018, 05:53 PM
Onebrokegoat's Avatar
Holley Sniper EFI. You’ll never have starting problems again. This also includes an electric pump btw.
Onebrokegoat is offline
post #10 of 43 (permalink) Old 12-05-2018, 08:34 PM
Quoted: 36 Post(s)
Electric fuel pumps are also noisy. I have one on a non Pontiac vehicle. How is your choke working?? On my '71 GTO, I converted the choke to electrical and the motor does start better after sitting a while. I was experiencing some problems similar to yours. If you do install an electric pump, do you plan on keeping it on continuously or just when you want to start the car after sitting a while?? If you do use it just for starting, in addition to possibly putting it on a relay, wouldn't you also have to install a toggle switch to control on and off??
Nicholas is offline
hard start after sitting colobronco 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 11-12-2016 01:13 PM
06 GTO stalls while cranking Jwtlakeland Service, Maintenance and Technical Discussion 1 03-23-2012 03:25 PM
Best Mods to cure wheel hop and rear squatting Left Coaster Drive train, suspension, alignment and brakes. 24 01-23-2012 08:35 AM
long sitting gas tank Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 11-03-2010 06:17 PM
5th Annual Cruisin' For A Cure redgtosamurai The Lounge 0 08-13-2004 01:12 AM
