Manual to power brakes - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-23-2017, 11:27 AM Thread Starter
Luckycat's Avatar
I currently have manual ( no booster ) brakes with disk on the front front and drum rear of my 70 GTO...is there a big advantage to switch to power brakes and is this done by just adding a booster and running vacuum line to it?
Luckycat is offline
post #2 of 3 (permalink) Old 01-23-2017, 12:47 PM
It's been so long since I drove a car with manual brakes.... Power brakes will definitely require a lot less pedal effort for the same stopping power, but if you're already able to lock up all 4 wheels with the manual system then power brakes aren't going to stop the car any 'better' (shorter distance) than what you have, as long as all 4 brakes are working at their max efficiency and are balanced correctly. Drum brakes tend to fade faster than disc because they don't cool as well, so you'd get some additional benefit from rear disc, but then the majority of stopping power comes from the front brakes which are already disc on your car, so ...
post #3 of 3 (permalink) Old 01-23-2017, 07:18 PM Thread Starter
Luckycat's Avatar
Makes sense..it stops just fine now..thanks bear
Luckycat is offline
Power Brakes Omni 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 08-21-2016 03:38 PM
70 GTO manual drum brakes WDMelvin 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 26 07-03-2014 11:41 AM
Power Brakes with Tri Power timmyg 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 3 08-21-2013 03:10 PM
1966 gto manual to power brakes johnnylightning03 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 11-16-2009 05:55 PM
