Master Cylinder Question - Pontiac GTO Forum
post #1 of 5 (permalink) Old 04-07-2019, 01:18 PM Thread Starter
Quoted: 12 Post(s)
Unfortunately it seems I need a new master cylinder after replacing everything else. I have disc on the front and drum on the back. Do I need a special Master Cylinder, Thanks for the help
keiko is offline
post #2 of 5 (permalink) Old 04-07-2019, 01:38 PM
BLK69JUDGE's Avatar
Quoted: 70 Post(s)
67 4 piston disc ?
BLK69JUDGE is online now
post #3 of 5 (permalink) Old 04-07-2019, 07:14 PM
Keiko,
You don't need anything special. Just pick up one from a local auto parts store. I will advise that you buy a new one and not a remanufactured. I just did my '69 a couple weeks ago and had 2 remanufactured one leak and I finally got a new one instead. It's well worth the cost, I think it was like $10 dollars more.
Good Luck,
Rob.
rkuchar69gto is offline
post #4 of 5 (permalink) Old 04-07-2019, 08:54 PM Thread Starter
Quoted: 12 Post(s)
Originally Posted by rkuchar69gto View Post
Keiko,
Good Luck,
Rob.
Hey thanks Rob. do I need the one with the round reservoir in front and the square in back ? the one I just took off had a 1.125 bore and a lot of them have a 1 inch bore dose it make a difference. Also would you happen to know if you can bleed the brakes without the car running. ?? Thanks for your help
keiko is offline
post #5 of 5 (permalink) Old 04-10-2019, 08:34 PM
Quoted: 33 Post(s)
Yes larger cavity in front for disc and small cavity in rear for drums. You can successfully bleed brakes without car running.
tjs72goat is offline
67 Drum Master Cylinder Question supergrizzly 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 13 05-09-2018 09:27 AM
'65 GTO disc brake/ master cylinder question PontiacDave 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 01-17-2011 10:25 PM
master cylinder question 66tempestGT 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 04-12-2010 08:35 AM
Brake Master cylinder replacement. Musicmike927 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 1 05-24-2009 07:57 AM
Correct Brake Master Cylinder 1970 aggie88 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 8 04-23-2007 12:28 PM
