Mystery third hose on 68 GTO gas tank...vent? - Pontiac GTO Forum
post #1 of 9 (permalink) Old 06-27-2019, 12:55 PM Thread Starter
I dropped the gas tank on my 68 GTO in order to replace the sending unit and upon dropping it discovered a 3/4 inch rubber hose at the front passenger top side of the tank...is this just a vent of some sort? I had no idea it was there until I dropped the tank and I dont know if it had been connected to something, although it doesnt appear to have had a clamp or fitting of any sort. Would like to know before putting the tank back in and finding out I should have done something with it. Thanks for all replies!!
John
jayvee53 is offline
post #2 of 9 (permalink) Old 06-27-2019, 02:23 PM
Quoted: 13 Post(s)
If I had to guess, it was someone’s previous attempt at a return line. Then, someone came along later and did it right with a return on the sending unit and abandoned the other one.
Colorado67GTO is offline
post #3 of 9 (permalink) Old 06-27-2019, 04:09 PM
Quoted: 79 Post(s)
It is a vent hose. There was a little filter thingy in the open end. Those usually disintegrate away as the years pass.
Shake-N-Bake is offline
post #4 of 9 (permalink) Old 06-27-2019, 05:44 PM Thread Starter
Thanks that's what I thought. After I spent additional time under the car I see there is a little metal "bracket" that the hose fits into and is held somewhat in place. All is good and the fuel gauge is working, so now I can literally watch the fuel consumption as I am tooling down the highway!
jayvee53 is offline
post #5 of 9 (permalink) Old 06-27-2019, 06:56 PM
Quoted: 390 Post(s)
You can purchase the filter end that goes on the hose from several of the Pontiac parts suppliers.
post #6 of 9 (permalink) Old 07-25-2019, 08:42 PM
Quoted: 20 Post(s)
That vent came with my new gas tank and my old tank had the same and was just a piece of hose pointing upward. That looked dangerous to me and figured since it is vented back at the fill pipe, why do I need it so I just plugged it off. Anyone know if this is not ok to do?
Red Skeleton is online now
post #7 of 9 (permalink) Old 07-26-2019, 04:26 AM
GTOJUNIOR's Avatar
Quoted: 66 Post(s)
I didn't see anything other then this illustration in the service manual.
If it were me I would leave it as factory and just be sure it has the Restricter and clamp in place.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #8 of 9 (permalink) Old 07-29-2019, 01:35 PM
Quoted: 20 Post(s)
Good advice, have the proper vent hose coming today, thanks for the great info!!
post #9 of 9 (permalink) Old 07-29-2019, 02:27 PM
Quoted: 20 Post(s)
Kind of disappointed at what I got from Inline Tube for about $18. A standard piece of hose with a little 3/4" piece of white foam stuffed in one end and a regular office staple where I guess it's supposed to hold the foam in place. I blew into one end of it and the foam came flying out the other!
