From No P.S & drum brakes - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-27-2004, 04:36 PM Thread Starter
to Power steering and disc brakes. Is it possible? and is ABS possible? Went for a drive and it is quite a work out trying to turn the wheel Braking is not that bad but doesnt feel that safe during hard braking. Overall, I love the damn thing and people do stare at it when you are driving. Maybe because they are used to high end cars around here
'67 GTO
'02 Porsche Carrera Cab
keoni1978 is offline
post #2 of 3 (permalink) Old 12-27-2004, 11:36 PM
Quoted: 11 Post(s)
Congratulations,
I've seen the kits for disc brakes on the 60's GTO, should not be a problem for power steering either.
Check out the links in this thread!
05GTO is online now
post #3 of 3 (permalink) Old 01-07-2005, 06:29 PM
keoni1978,
Where in OC do you live? Power steering and Disc brakes is easy on these cars. You can go from a simple/inexpensive brake conversion to a more extreem expensive set-up. Get in touch with me here and I can steer you in the direction you chose. I can show you what I have for my '67. A high end Wilwood disc brake set-up with large rotors, negative camber A-arms etc.
The Power steering is as easy as adding the pump/brackets and new steering gear.
Keith
Keith67 is offline
