Replaced Fuel Sending Unit, now trouble starting - Pontiac GTO Forum
post #1 of 1 (permalink) Old 08-02-2015, 05:45 PM Thread Starter
aeconfidential's Avatar
Hello, I have a 1965 Pontiac GTO (with a later year 455). Since the fuel gauge was not working (needle passed Full), I replaced the fuel sending unit. The old one has a 5/16 outlet and the new one that has 3/8 outlet...figured I will eventually upgrade the fuel line to 3/8 as well. The only visual difference between the units (besides the outlet size) is the 5/16 outlet is straight and the 3/8 outlet is angled up a little...maybe 45 degrees. The fuel line is up above the fuel tank so I'm sure sure this is an issue. Before changing the fuel sending unit, the car ran fine...I would pump the gas once or twice and it would fire right up. Now, I have to crank it and pump the gas repeatedly to get it to eventually start. Once it's running it's fine, but a lot harder to start now.
UPDATE: I swapped the old 5/16 sending unit back in and the car starts like it use to. Also, I cleaned the ground wire before install and the fuel gauge appears to be working. So for whatever reason, the bigger 3/8 outlet was causing an issue at start up.
aeconfidential is offline
68 gto fuel sending unit wings012345 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 07-07-2015 08:33 PM
70 Fuel gage problems replaced sending unit michaelrj9 1964-1974 Tempest, Lemans & GTO General Discussion 8 07-11-2013 11:14 AM
Fuel sending unit Piedog 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 04-09-2013 09:14 AM
Fuel sending unit/fuel gauge issue xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 08-08-2012 08:12 PM
What is the differance fuel sending unit 67 Lemans John 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-22-2008 03:49 PM
