Size of the rear upper trailing arm bushing ?? - Pontiac GTO Forum
 2Likes
  • 1 Post By PontiacJim
  • 1 Post By cij911
post #1 of 6 (permalink) Old 08-20-2018, 11:38 PM Thread Starter
Quoted: 155 Post(s)
I purchased the Spohn del-sphere rear trailing arms and the rear upper does not fit on the the pumpkin / diff side. It appears the opening is much smaller than the supplied bushing, yet Spohn claims they are all the same from 64 - like 80 something (can't remember). Is this possible or is it possible the BOP rear's were unique and Spohn is unaware ? Or is it possible that I have a different rear end hahah ?
Ideas ?
ID:	114913   Click image for larger version
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #2 of 6 (permalink) Old 08-21-2018, 01:45 AM
Quoted: 391 Post(s)
Ideas ?
As I recall, 1964 is different and smaller than 1965 and up, so possible you have a 1964 rear axle.
Strange how Spohn would claim they are all the same when they have a separate bushing for "1964" only and a different one for 1965 and up on their own website. Must have been talking to a representative in India. Check this out, then give them a butt chewing and get your money back: https://www.spohn.net/shop/1964-1967...u-GTO-etc.html
post #3 of 6 (permalink) Old 08-21-2018, 06:55 AM Thread Starter
Quoted: 155 Post(s)
Thanks Jim!
If it is a 64 rear end, that begs another question - why ??? Amazing how you think you have everything identified on a car, only to find surprises....I guess I should open the diff and see what is inside....
Current setup:
4 speed Muncie
post #4 of 6 (permalink) Old 08-24-2018, 11:09 AM Thread Starter
Quoted: 155 Post(s)
64 rear bushing is ~1.4" diameter.....unfortunately I was not able to find a del-sphere or heim joint so I went with the standard rubber bushing. I will continue looking for a heim joint solution.
Current setup:
4 speed Muncie
post #5 of 6 (permalink) Old 08-24-2018, 05:48 PM
Quoted: 391 Post(s)
Your car may be factory correct with the '64 rear axle depending on date build.
What you are showing in your photo looks like a solid bushing with a pivoting center like a Heim joint, am I correct?
I would not use a solid bushing. The rubber bushing is what I used because I want a means to absorb some of the acceleration/road shock placed on the rear axle. If you go solid, the forces will find the next weakest point to stress and something could crack, break loose, or you may find that your attachment bolt holes at the crossmember may elongate from the acceleration and deceleration cycles.
I used the UMI adjustable upper control arms with the Roto-Joints ends. I am using a Ford 9" and custom suspension set-up, so I had to modify these and actually have them reversed for my application - rubber bushing is now on the frame side brace attachment and Roto-Joint at the rear axle. 1968-1972 A-Body Adjustable Upper Control Arms- w/ Roto-Joint [4037] - $259.99 : UMI Performance, Inc. Of course Spohn has the Del-Sphere joints as well. https://www.spohn.net/shop/1964-1967...djustable.html
You would also want to add the upper & lower control arm braces if your car does not already have them. This will make the crossmember that your upper control arms attach to more rigid and flex less thus preventing any fatigue or stress cracking. I used the UMI brace on my '68. It is adjustable for an easier fit.
Name:	05  Upper control arm.JPG
ID:	114999   Click image for larger version
Name:	06  Upper control arms completed.jpg
ID:	115001   Click image for larger version
Name:	UMI  UCA-LCA Braces.jpg
cij911 likes this.
post #6 of 6 (permalink) Old 08-25-2018, 08:09 AM Thread Starter
Quoted: 155 Post(s)
Yes Jim I had to go with a rubber rear upper bushing on the pumpkin / differential housing. All the other bushings on the rear are Del-Sphere from Spohn.
I replaced the front end and took the car out for the first time in 1 1/2 weeks and it is a night a day difference.
PontiacJim likes this.
Current setup:
4 speed Muncie
69 trailing arm bolt question greenjudge69 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 10-10-2017 09:45 AM
Rear Control Arm and Bushing recomendations please bowtie30 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 14 03-23-2015 05:59 PM
Rear control arm bushing replacement mbergin 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 23 04-28-2014 07:21 PM
Trailing arm bushings orelog 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 06-27-2012 04:29 PM
1966 LeMans - Rear Trailing arms Bensjammin66 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 7 12-22-2010 02:17 PM
