steering column swap - Pontiac GTO Forum
 1Likes
  • 1 Post By Pinion head
post #1 of 2 (permalink) Old 05-03-2016, 11:18 AM Thread Starter
3GTOs's Avatar
I have a '65 Lemans that I would like to change the column shift steering column to a '67 Lemans/GTO floor shift column to get the benefit of the energy absorbing feature.
Would it fit?
3GTOs is offline
post #2 of 2 (permalink) Old 05-03-2016, 11:49 AM
The two places of possible interference are:
- where the column attaches to the "hanger bracket" that holds the column up. the '67 bracket is different than the '66 in its shape for this reason. I'd bet there will have to modifications to your original pedal hanger bracket.
- at the opening of the lower dash where the lower bowl abuts the opening. Believe it's larger on a '64 or '65. On a '66, it has the large dash bezel with the smaller radiused area for the column tube to tuck up against. A '64-66 column will fit properly, but a '67 column when used with a '66 dash bezel interferes in that area.
Wish could be of more help, if I had a '64 or '65 partscar in the line, could test fit a '67 style column.
3GTOs likes this.
How do I get steering column off? smac8876 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 09-03-2013 09:17 PM
Help w/steering column Instg8ter 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 11 03-22-2012 07:19 PM
