Tie rod zerk location - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-22-2017, 01:14 PM Thread Starter
I have received two separate "inner" tie rods with the grease zerk located on the back plate instead of the end of the casting like the original. Is this a problem?
Rushm is offline
post #2 of 4 (permalink) Old 01-22-2017, 02:59 PM
shader's Avatar
Quoted: 9 Post(s)
Sounds like you may have the wrong parts. All the inner rods I have seen have the fitting on the end of the casting, and the outers have the fitting on the end cap. There is not much room between the frame and the inner tie rod so the fitting is on the end. Also, it would be a real PITA to fit the grease gun in that space. If I remember correctly the inner tie rod had more threads than the outer if you are able to compare.
shader is offline
post #3 of 4 (permalink) Old 01-23-2017, 06:52 PM Thread Starter
I agree that space is really tight. It is just frustrating that I have received the wrong part twice now.
Thank you
Rushm is offline
post #4 of 4 (permalink) Old 04-30-2017, 06:43 PM
Quoted: 117 Post(s)
Not a problem if you install 90 degree grease fittings. Many replacement tie rods have a center-mounted fitting. Not wrong, just different.
Tie rod end DrFix2Fly Drive train, suspension, alignment and brakes. 31 06-05-2011 09:22 PM
tie rod ends Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 10-26-2010 07:16 AM
Need Tie Rod hypegotgto Drive train, suspension, alignment and brakes. 1 03-09-2010 02:52 PM
05 GTO L/H Inner Tie Rod Who Has Just The Rod beaudee Drive train, suspension, alignment and brakes. 1 11-05-2009 01:51 PM
Tie Rod goatcrazy88 Drive train, suspension, alignment and brakes. 2 03-31-2009 10:52 AM
