Wilwood Parking Brake Cable - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-16-2015, 05:32 PM Thread Starter
DTM
We have installed Wilwood rear disc kit on a '66 GTO and are getting custom cables made to utilize the "factory" cable setup. Can any one provide the length of the cable that is from the frame hole where the housing stops / connects to the intermediate cable links?
Attached is a file that has a simple drawing of the cable setup. Need the far lefthand length measurement (the one within the circle).
Thanks,
David
DTM is offline
post #2 of 3 (permalink) Old 07-17-2015, 08:44 AM
David, while I don't have that measurement for you, I would simply substitute some twine for that cable and measure that.
post #3 of 3 (permalink) Old 07-18-2015, 02:47 AM
You're making it too hard. I used a Lokar 'cut to fit' e-brake cable kit with my Wilwood's and they worked just fine.
68 Parking Brake Cable 68basketcase 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 7 10-31-2015 09:40 AM
Wilwood Rear PArking Brake Cable DTM 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 0 01-03-2014 06:09 PM
Parking Brake Cable Install -- Lessons Learned rwhitaker 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 06-09-2012 12:28 PM
65 parking brake cable parts crustysack 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 06-21-2010 09:49 PM
Help With Parking Brake Cable Removal WideTrack 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 08-06-2008 06:45 PM
