1964 GTO firewall tag/serial - Pontiac GTO Forum
post #1 of 19 (permalink) Old 09-22-2017, 10:37 AM Thread Starter
firemedic835's Avatar
I have just purchased a 1964 GTO Can anyone help me figure out all the codes?
The Firewall tag is as listed
PONTIAC DIV. GENERAL MOTORS CORP.
07E PONTIAC MICHIGAN
STYLE 64-2237 BODY PO 24573
TRIM 217 PAINT P-P
ACC. 1W-2P-5N-5W
BODY BY FISHER 12-2
The serial number on the door is as listed
PONTIAC
824P298622
firemedic835 is offline
post #2 of 19 (permalink) Old 09-23-2017, 10:13 AM
Quoted: 78 Post(s)
TRIM 217 PAINT P-P
ACC. 1W-2P-5N-5W
BODY BY FISHER 12-2
PONTIAC
824P298622
I will give it a try....
07E: last week in July (E being the 5th week)
64-2237: 64=1964 model year, 22=LeMans, 37=2 door hardtop
PO 24573: Fisher Body plant in Pontiac MI, 24573 is a number used for sequencing in the Fisher Plant.
Trim 217: interior color Aqua
Paint P-P: Aquamarine metallic
ACC: accessory list for Pontiac and Kansas City Fisher Plant items
1W:tinted windshield
2P:radio
5N:GTO group
5W:unknown....could possibly be 2W? If so, that would denote the 2 speed automatic with 389 engine
Serial number on door is the VIN
8 =engine cylinders
2=LeMans
4=1964 model year
P=Pontiac final assembly plant
298622=assembly plant serial number
You can contact PHS and send for the production docs. If available for your car, then you will receive paperwork that may validate the GTO package was ordered for your LeMans.
Shake-N-Bake is offline
post #3 of 19 (permalink) Old 09-23-2017, 02:34 PM Thread Starter
Thank you very much I will try to get a better picture of the Vin number
post #4 of 19 (permalink) Old 09-23-2017, 02:36 PM Thread Starter
Here is what I believe is the 5w
post #5 of 19 (permalink) Old 09-23-2017, 02:39 PM Thread Starter
It has a 4 speed manual trans
post #6 of 19 (permalink) Old 09-23-2017, 03:06 PM Thread Starter
Also a 389 Tri power,
ID:	96962   Click image for larger version
post #7 of 19 (permalink) Old 09-23-2017, 08:34 PM
Quoted: 78 Post(s)
That last accessory code sure looks like a 5 to me. My book only shows two possible codes for group 5. N for GTO and Z for seat belt delete. The book also says that delete option was Pontiac plant only. Does your car have seat belts?
Sounds like a great car you have there.
post #8 of 19 (permalink) Old 09-23-2017, 08:35 PM
No 2LG, just a 2P.
5W is a seatbelt option
Trim tag reads like car was originally built with 3 speed.
To determine if original Tripower optioned car, wil need to look at PHS copy of original build card.
post #9 of 19 (permalink) Old 09-24-2017, 04:05 PM Thread Starter
Yes it has retractable seat belts
post #10 of 19 (permalink) Old 09-24-2017, 07:29 PM Thread Starter
The GTO option with the 389 Tri power was only an option in Pontiac Ms and KS. 5N means GTO option. As far as I can research. Please let me know if you find something different.
ID:	96986   Click image for larger version
ID:	96994   Click image for larger version
ID:	97002   Click image for larger version
ID:	97010   Click image for larger version
1968 gto chassis serial # location frankrp 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 02-01-2016 08:55 AM
1969 gto judge engine serial # source? Sanchito75 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 5 11-16-2015 07:06 PM
68 serial numbers Matthew 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 15 03-25-2013 01:11 PM
65 frame serial # location? pbertrand65GTO 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 05-15-2011 06:18 PM
1964 GTO Acc Data Tag ?? 5N GTO wesleychapel 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 09-26-2006 09:48 AM
