1965 GTO Cowl Tag - Pontiac GTO Forum
post #1 of 4 (permalink) Old 12-15-2014, 03:15 PM Thread Starter
1965 GTO Cowl Tag
This is a Freemont, CA built car:
TR 213 30 213 is black vinyl. What is the 30?
ACC 08442 What is the 08442?
22 embossed into the tag in upper right corner above body #. What is 22?
Is there any way to determine GTO on Freemont cars, except by PHS doc?
sdseay is offline
post #2 of 4 (permalink) Old 12-15-2014, 03:28 PM
Roger that's Avatar
213-30 is the code Fremont uses for black interior.
08442 would be in the bottom right corner and that is the plant's manifest sequence number.
2 2 is Fremont's fixture or gate number. This refers to where the body was welded: Gate 2, 2nd shift.
PHS is the GTO way.
Roger that is offline
post #3 of 4 (permalink) Old 12-15-2014, 05:54 PM
Quoted: 98 Post(s)
I determined my GTO was a 'real' one decades before I bothered with a PHS. I had the Protect-O-Plate, which had the Engine Unit Number: "WS 127xxx". No WS engines came in Tempest's or LeMans's!!! So, if you have the Protect-O-Plate, you can tell it's a GTO by the engine code. "WS, WT, YS", etc. If it has a 389 and the VIN matches your car, it's a real GTO. Mine's a Fremont build, too.
post #4 of 4 (permalink) Old 12-15-2014, 06:06 PM
Roger that's Avatar
Yes Protect-O-Pate is as good as gold. Problem is few cars still have them. Having one with a 64/65 GTO adds $10,000 and more in value (my opinion of course).
1965 Gto Cowl Tag Codes ???? D1147 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 6 11-13-2014 07:32 PM
1965 GTO Cowl Tag question riggsjr 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 6 07-15-2014 07:54 AM
1967 GTO 400 HO cowl tag turbopedro 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 9 05-12-2014 05:48 PM
Cowl Tag Petey D 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 5 03-11-2010 01:38 AM
1971 GTO cowl tag question????? samanatoo 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 10-01-2008 09:01 AM
