1965 GTO Cowl Tag question - Pontiac GTO Forum
post #1 of 7 (permalink) Old 05-18-2014, 03:04 PM Thread Starter
I have noticed since I have been researching that the the Pontiac Michigan and the Kansas City cars were far heavily coded to the options on the vehicles than California cars.Is this true? Also that I think they did not always have the 5N on the tag in the Fremont plant even if it was a GTO. Am I correct on this statement also?
riggsjr is offline
post #2 of 7 (permalink) Old 05-19-2014, 07:45 AM
SANDU002's Avatar
You are correct about Pontiac & KC stampings. I had read somewhere that some Fremont cars did have the 5N stamping, but I don't recall why.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #3 of 7 (permalink) Old 05-19-2014, 10:52 AM
The Fremont plant used UPC codes for their Accessories and I don't think they had a UPC code for the GTO option. The only way to confirm Fremont and Baltimore built GTOs in 64&65 is with the PHS documentation.
05GTO is offline
post #4 of 7 (permalink) Old 05-19-2014, 02:11 PM
Quoted: 98 Post(s)
Fremont cars do not have the 5N stamping. Only PON and KAN cars. In addition, Freemont tags are left bare metal, have a border all the way around, and say "this vehicle finished in magic mirror laquer" in script at the bottom. The date codes on Fremont cars are different too: single didget for the single didget month, wihout a 'o' in front of it. Maddening stuff when you are trying to sort it all out!!
post #5 of 7 (permalink) Old 07-14-2014, 07:55 PM
datatagdecoder is offline
post #6 of 7 (permalink) Old 07-14-2014, 09:25 PM
Roger that's Avatar
Is this supposed to decode the accessories? For example if I wanted to know what 5N meant does your program tell me? I could not get it to work.
Roger that is offline
post #7 of 7 (permalink) Old 07-15-2014, 07:54 AM
It seems to be working properly, the 5n only appears for 64 and 65 when the Pontiac or Kansas City plants are selected on the top of the vin tag.
ID:	41945   Click image for larger version
05GTO is offline
1965 Gto Cowl Tag Codes ???? D1147 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 6 11-13-2014 07:32 PM
1967 GTO 400 HO cowl tag turbopedro 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 9 05-12-2014 05:48 PM
Newbee here with a cowl tag question outerbanks 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 4 11-24-2013 05:55 PM
Cowl Tag Petey D 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 5 03-11-2010 01:38 AM
1971 GTO cowl tag question????? samanatoo 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 10-01-2008 09:01 AM
