1966 GTO Carburetor 4034S Question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-09-2018, 07:21 PM Thread Starter
Hey, I am restoring a 66 GTO for my dad. It is a 389 4bbl Automatic with a date correct engine. When I purchased the car the carburetor and intake manifold were sitting on the engine and not bolted down. This raised questions for me as there were over 30 gtos in the barn that I bought mine from, so I was worried it wasn't correct. While investigating my carburetor it had a pink tag on it reading ďCO PC 4248sĒ which I was told was incorrect for a 389 and it was for a 326. I was told I needed a 4034S. I ordered a rebuilt 4034S and when it arrived it looks identical to the carburetor I had. I am looking to find out what the difference is between the 4248s and 4034s, and what carburetors I have in front of me? Attached are photos of the carb that came with the car and the one I just received, along with the tag and photo of the car. Thanks in advance for all the help.
ID:	106009   Click image for larger version
ID:	106017   Click image for larger version
ID:	106025   Click image for larger version
Mastergreenbean is offline
post #2 of 3 (permalink) Old 03-09-2018, 09:06 PM
Quoted: 347 Post(s)
4248S shows up as a 1967 285HP 326/automatic on the Firebird & Tempest/GTO having A.I.R.(Air Injection passages for the exhaust - Smog equipped engines).
4034S shows up as a 1966 335HP, Block Code YS, 389/automatic Tempest/GTO, non A.I.R. engine. Also used on 1966 B-Body 389/automatic cars.
That said, the carbs are engine/trans specific, with and without A.I.R. passages, and most likely fitted with application specific internals such as jets, step-up springs/metering rods, and idle-air bleeds.
post #3 of 3 (permalink) Old 03-09-2018, 11:41 PM Thread Starter
Hey thanks for the reply, are you saying that the 4034s is correct and it is ok that they look the same and the difference between them is internal?
1966 Carter Carburetor dashpot gtoguy389 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 13 02-28-2016 11:56 AM
carburetor torque question - 74 GTO Red74Goat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 08-24-2015 01:00 AM
question about the radiator-1966 gto Berto504 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 09-20-2014 06:54 PM
belt replacement question-1966 gto Berto504 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 08-05-2014 10:27 PM
carburetor question Topkat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 10 01-07-2011 05:22 PM
