1966 GTO drive shaft and slip yoke - Pontiac GTO Forum
post #1 of 5 (permalink) Old 05-02-2016, 02:48 PM Thread Starter
Trying find out the difference between slip yokes. Apparently the slip yoke for a two speed TH300 is half inch shorter than the slip yoke for 4 speed manual. Is that correct?
Thanks!
.....Mark
1966 GTO Convertible Automatic
Markd15668 is offline
post #2 of 5 (permalink) Old 05-21-2016, 06:43 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
Someone correct me if I'm mistaken, but I did this on my '66 and do not recall changing the yoke.
This was many years ago, so I looked through my files and found nothing in as far as invoice for such.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 5 (permalink) Old 05-23-2016, 05:38 PM
Quoted: 347 Post(s)
I don't think there is a difference either. Now the driveshaft length may be different as an automatic is usually longer than the 4-speed - but I can't swear to it.
post #4 of 5 (permalink) Old 05-23-2016, 07:18 PM
-No difference in driveshaft yoke part number between '64-68 Super Turbine 300 transmission and the same original usage yoke used on the small output shaft Muncie 4 speed. same part number yoke was used on the base Tempest 3 on the tree 3spd transmission.
-Stock driveshaft in '64-67 Pontiac 2 door Abody with either ST300 or small output shaft Muncie 4 spd, or base 3spd in the 326 Tempest, will be 60.00" measured center to center on the 3R ujoints.
-'67 T400 used in the GTO, used a 5/8" shorter driveshaft, 59.375", center to center.
- '66-69 Pontiacs with the HD "top loader style" 3spd used their own yoke and their own length driveshaft. I currently do not have one of these in the driveshaft barrels to measure. Hope this helps!
post #5 of 5 (permalink) Old 05-23-2016, 07:55 PM
Quoted: 347 Post(s)
Perfect. Thanks for that answer PH.
Drive shaft Gto x Service, Maintenance and Technical Discussion 4 09-23-2015 04:39 PM
Drive shaft yoke engagement 68Temp 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 4 05-18-2015 09:07 PM
drive shaft? hemi1282 Service, Maintenance and Technical Discussion 6 10-21-2013 08:11 AM
drive shaft mikey9743 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 03-03-2013 08:56 AM
TH400 Locking to Slip yoke conversion gckeith66 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 01-04-2012 03:21 AM
