1967 GTO Data Plate Decode - Pontiac GTO Forum
post #1 of 15 (permalink) Old 04-12-2015, 11:13 PM Thread Starter
Vmax67's Avatar
Hi,
I have gotten out my 1967 GTO after it has set for a number of years. Its running good. I have the PHS docs and its a very nice original car.
I have been trying to decode the data plate on my GTO. A picture is attached. I can get most of the data such as the black bench seat, signet gold, Baltimore Assembly, build date, body number, ect. but I am stumped by the 671 number at the top of the plate (I think it could be number 671 GTO built at the Baltimore plant on December 6, 1966 but I am not sure?). I have no idea what the 219161 means at the bottom of the plate. It does not coincide with the VIN or the engine number. I can not seem to find these numbers on other data plate examples. Any help would be welcomed.
Vmax67 is offline
post #2 of 15 (permalink) Old 04-13-2015, 12:55 PM
Roger that's Avatar
671 is your Daily Sequence number or sometimes called the job number that resets each day. This would include all makes of cars for the BAL plant since they made more than just Pontiac GTOs.
219161 is the manifest sequence number that spans across the model year that is internal to the plant.
You also have what appears to be a gate number of 6 (upper right hand corner above the word BODY). This is the location of where your chasis was welded up in the plant.
Roger that is offline
post #3 of 15 (permalink) Old 04-13-2015, 02:22 PM
67Twistytee's Avatar
Also, in response to your other question, your tag indicates a first week Dec '66 build date. Early 67 GTO's only came with an engine EUN code on the passenger side of the block. It does not correspond to the VIN. Later in the model year they added a second stamp near the timing cover with the "2" for Pontiac division, 67 for the model year and last 6 digits of the VIN. The only way to verify if the block is original on the early cars is by matching the EUN on the PHS to the block and verifying the date code on the distributor pad.
Lastly, it looks like you have a "G" for console car below the code for the bench seat. I thought the console was only available with bucket seats. Anyone else know what this means?
Andy
'67 GTO/Signet Gold over Parchment/Pontiac Built
67Twistytee is offline
post #4 of 15 (permalink) Old 04-13-2015, 09:19 PM Thread Starter
Vmax67's Avatar
Thank you guys,
Rodger that - I did not see the 6 in the upper corner of the data plate. Thank you for pointing that out. The 671 also showed up on a tag I found under the seat and it says Job Number. I understand it is some kind of daily plant total. Picture attached. Manifest Sequence number is also now understood.
67Twistytee - On the right side of the engine block shows YZ and the number above the letters matches the PHS Engine Unit Number (098428). See Picture. Date codes are:
Engine Block J266 = October 2, 1966
Casting Date: September 26, 1966
Carb: 3895S
Casting date: J296 = October 29, 1966
Carburetor: 7027262 L6 WA
I believe the engine, trans and rear end are original.
The car has a manual black bench seat with a fold down center arm rest?
ID:	55209   Click image for larger version
ID:	55217   Click image for larger version
Vmax67 is offline
post #5 of 15 (permalink) Old 04-13-2015, 10:02 PM
Roger that's Avatar
The code of 235 on your cowl tag is the black "Notchback Strato bench seat". This came with the fold-down armrest which was only available on the 2 door LeMans and GTOs.
post #6 of 15 (permalink) Old 04-13-2015, 10:09 PM
If original that YZ block would indicate it's an automatic HO engine. Very rare for a bench seat, column shift car. Most automatic GTOs came with a YS block. '67 auto 4-barrel carb should be a Rochester #7027262 so that looks original. The engine dates look correct for a Baltimore built car with a early Dec '66 build date, but the the YZ code is strange. Did you order the PHS and does it indicate this is an HO car?
You should be able to get the rear end code of the driver's side axle tube, readable when facing the rear of the car. Should be a 2 letter code.
The TH400 tranny should have a riveted tag on the right hand side. You should be able to match this to the date of the car build.
The build sheet you found also lists Group 2 R (rear seat or rear speaker?); Group 3N (roof reading lights); Group 4 G (this could be the arm rest since their were two bench seat versions offered in 1967) & H (heater delete?); Group 5Y are the custom seat belts.
Andy
post #7 of 15 (permalink) Old 04-13-2015, 10:49 PM Thread Starter
Vmax67's Avatar
I will post the PHS docs tomorrow. Original owner said he ordered a bench seat, column auto and HO motor. He thought it was the fastest package at the time. PHS docs confirm HO motor, column auto., bench seat. It has the Ram Air manifolds and heat shield still in place. Rear is.3:55. PHS docs show wide oval red lines but no indication of wheels. Owner said he ordered wire hubcaps but the ones in the trunk when I picked it up were 1966 wire hubcaps? Not 1967s? I will have to get under it to check trans and rear end codes this weekend.
Vmax67 is offline
post #8 of 15 (permalink) Old 04-13-2015, 10:57 PM Thread Starter
Vmax67's Avatar
Almost forgot it has courtesy reading lights on both sides, rear speaker, am fm, power steering, retractable seat belts, clock, tinted windows, original paint and painted pin stripe. It does have a heater however. Also trunk and engine compartment lights.
Vmax67 is offline
post #9 of 15 (permalink) Old 04-13-2015, 11:04 PM Thread Starter
Vmax67's Avatar
TwistyTee! My car was delivered in Siler City NC. Near you?
Vmax67 is offline
post #10 of 15 (permalink) Old 04-13-2015, 11:06 PM
Sounds like you have a very nice, all original car. Great that it still has the original block and RA manifolds. Mine is the same color with pin stripes too, but its had a respray and the pin stripes were reapplied by hand.
Did he do any work to the engine to lower the compression? Mine is still standard bore but with an added 068 cam. It pings with the original 670 heads. I've been mixing in race gas but have decided to bite the bullet and rebuild the engine to lower the compression. It's too much of a pain to drive it any distance on today's gas.
Good luck with the car and post some more photos!
Andy
Data Plate decode SIXT5GTO 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 7 07-16-2013 08:06 PM
1967 GTO Vin and Data plate robtx 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 8 08-21-2012 08:12 PM
Figuring out 65 GTO Data Plate DaleGolds 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 12 12-17-2010 01:10 PM
1967 GTO data plate color help bluekrypto 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 12 12-03-2008 09:07 AM
64 GTO Data Plate-Need Help Vaughan Walraven 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 7 07-21-2006 11:05 PM
