'65 GTO Data Plate - Pontiac GTO Forum
post #1 of 8 (permalink) Old 07-04-2015, 09:50 AM Thread Starter
'65 GTO Data Plate
The build date on the firewall tag in upper left corner is 19A X. What is that date?
army6741 is offline
post #2 of 8 (permalink) Old 07-04-2015, 10:51 AM
Quoted: 106 Post(s)
Originally Posted by army6741 View Post
The build date on the firewall tag in upper right corner is 19A X. What is that date?
1965 GTO Specifications - UltimateGTO.com
Goat Roper is offline
post #3 of 8 (permalink) Old 07-04-2015, 02:42 PM Thread Starter
thanks but the # on my plate is 19A
army6741 is offline
post #4 of 8 (permalink) Old 07-04-2015, 03:25 PM
Quoted: 106 Post(s)
I checked the sites I know of and 19A means nothing.
Can you post a pic of your plate?
post #5 of 8 (permalink) Old 07-05-2015, 08:47 AM Thread Starter
Thanks goat roper. It has been documented by PHS. I see no date on that packet except on the billing history card of 11 05 4. is that the order date? vin # 237275P118754. I still don't know what the 19A X date in upper left corner of data plate on firewall is. I seen a question on here quite a while ago from someone with a a '65 who also had tha 19 A on his plate, but there was no response. thanks.....
army6741 is offline
post #6 of 8 (permalink) Old 07-05-2015, 11:17 AM
Quoted: 106 Post(s)
I believe that is the invoice date, the build date code should be on the data plate in the upper left.
Vin decodes as a 1965 Pontiac LeMans and GTO 2 door sport coupe built in Pontiac MI with a V-8 engine.
Pretty new to Pontiacs myself so maybe someone else who knows more will chime in.
post #7 of 8 (permalink) Old 07-05-2015, 11:27 AM
Roger that's Avatar
I thought I gave some info to you on this a while back ago: https://www.gtoforum.com/f12/online-c...73/index2.html Post number 16.
The person that was stamping your number for the month on the cowl tag was having a bad day.
389, transistorized ignition, and a power pack of 3 deuce carbs..... and she chews up other cars and 426 Mopars.
Roger that is offline
post #8 of 8 (permalink) Old 07-05-2015, 08:13 PM Thread Starter
thanks Roger That. I missed that information you posted a while ago. That explains it.
army6741 is offline
68 GTO Data plate vs VIN wishihaditback 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 03-25-2015 06:41 PM
1965 GTO data plate help GTO4MJB 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 5 07-03-2013 06:21 PM
Data plate decoding GTO-68 GTO viking 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 2 07-26-2011 05:58 PM
Figuring out 65 GTO Data Plate DaleGolds 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 12 12-17-2010 01:10 PM
64 GTO Data Plate-Need Help Vaughan Walraven 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 7 07-21-2006 11:05 PM
