68 cowl tag. - Pontiac GTO Forum
 1Likes
  • 1 Post By GTOJUNIOR
post #1 of 6 (permalink) Old 02-12-2019, 05:15 AM Thread Starter
Anderslober's Avatar
68 cowl tag.
Hi forum.....need this body tag decoded. Especially the upper numbers.....Thanks.
Please confirm that the body tag does NOT always correspond to the vin tag.....??? Thanks.
Anderslober is offline
post #2 of 6 (permalink) Old 02-12-2019, 11:10 AM
1968gto421's Avatar
Quoted: 70 Post(s)
This has been done as a sticky but to expedite things here is the link to the site you need to de-code all this stuff:
Welcome to DataTagDecoder.Com | DataTagDecoder.Com
Best of luck.
1968gto421 is offline
post #3 of 6 (permalink) Old 02-12-2019, 06:19 PM
Quoted: 350 Post(s)
Looks a little funky with the gobs of goop on the rivets and the Data Tag doesn't appear to lay flat on the firewall. Confirm the VIN number on the dash with the stamped VIN on the drivers side frame rail just past the arch. It should be either stamped on the side or on top of the rail. You will have to do some cleaning to see it. This will authenticate the car and confirm the Vin's match. Then......
Order the PHS factory documents for your car by its VIN which will confirm what is on the Data Tag as well as options presently on the car. Many fakes out there as well as stolen parts/pieces cobbled together.
post #4 of 6 (permalink) Old 02-13-2019, 04:27 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
Those gobs of putty are common, the rivet showing looks to in perfect condition as dose the plate its self.
I think its the shadows that make it look curved/bent but that is one is clearly very flat and untouched.
The above decoder works well and would only suggest PHS if you think there is something unique about this '68 and you plan to restore it back to as built.
JM2C
Cheers.
jmt455 likes this.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #5 of 6 (permalink) Old 02-13-2019, 06:32 AM Thread Starter
To me..it looks very original. I need help with the upper number row(s).....what do they mean?
The datadecoder did not help in this regard......
Any ideas? Thanks.
post #6 of 6 (permalink) Old 02-13-2019, 04:21 PM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
1ST 3 Digits are the build date, 03A/ 03=Mar. A=1st week.
The 2nd & 3rd sets of 6 digits relate to Daily Production sequences and as far as I know can not be broken down and/or offer any useful info.
This was for the line crews.
1965 Gto Cowl Tag Codes ???? D1147 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 6 11-13-2014 07:32 PM
Cowl Tag Petey D 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 5 03-11-2010 01:38 AM
top cowl plate where the V.I.N tag attaches DrBoeing 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 9 11-18-2009 08:24 AM
1971 GTO cowl tag question????? samanatoo 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 10-01-2008 09:01 AM
1966 cowl tag jeremy 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 5 04-11-2007 06:14 AM
