'68 GTO / LeMans VIN Plates? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 06-11-2011, 11:00 AM Thread Starter
SixTeight's Avatar
Now that I have the '68 GTO and '68 LeMans sitting side by side in the garage, I have a question about the VIN tag locations...
1968 GTO:
1968 LeMans:
The LeMans (originally an A/C car) has clearly had its original dash replaced with that of a '68 GTO non AC, as the VIN reads 242378R1XXXXX and the data sheet says 23737.
My biggest question is why the VIN's are in two difference places on the dash on these two cars relative to the windshield.
SixTeight is offline
post #2 of 4 (permalink) Old 06-11-2011, 12:32 PM
lewy222's Avatar
It's kind of hard to tell from your pics but if I am looking at them right, the red one is the one that is wrong. The vin tag is isnt located close to the windshield on a 68 and the rivets are shot on from under the dash. Also, the rivets on the red one are just standard rivets, not the rosette rivets that should be there, or at least that's how it appears.
lewy222 is offline
post #3 of 4 (permalink) Old 06-11-2011, 12:41 PM
lewy222's Avatar
It also looks like the trim tag on the Lemans has been relocated...those holes just under the tag arent there on my car.
lewy222 is offline
post #4 of 4 (permalink) Old 06-11-2011, 01:12 PM Thread Starter
SixTeight's Avatar
That would make sense... the previous owner chopped the original dash in half and installed this "custom" *choke* one instead which starts after the point where the VIN is located on the LeMans. On of the main reasons I bought the LeMans is because I wanted the GTO to have an original dash, so it looks like I will have to replace the entire panel and swap the VIN tags as well, as the dash in the white car will be going into the numbers matching orange car...
GTO VIN, Data Plates and Engine Codes 05GTO 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 15 10-28-2013 11:04 PM
Transmission vin code on a 70 Lemans? russosborne 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 8 02-02-2011 05:16 PM
1965 Gto data plates code and engine date alsgto 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 12-06-2009 05:16 PM
Personalized fire plates for 2006 GTO Daisey_Moonshine The Lounge 10 05-15-2007 01:20 PM
