69 Frame VIN location-Where is it. - Pontiac GTO Forum
post #1 of 2 (permalink) Old 09-20-2013, 05:19 PM Thread Starter
I have a project GTO that is clearly not original. Its a definite GTO VIN on the dash but I want to verify the frame VIN. (The block is not original). Ive read conflicting things about the frame VIN. Consensus is it's on the driver's side rear frame rail...but exactly where? Front of the rear tire or rear of it? Also...a few mention you would need a mirror to see it? And some mention it can't be seen unless body is removed. If frame is off...why do i need a mirror?
Anyone have a definite answer. If its not a GTO frame but a LeMans or Tempest frame...anyway to tell?
GTOALAN is offline
post #2 of 2 (permalink) Old 09-20-2013, 09:54 PM
Top of the frame rail, behind the rear tire. On my 69 it's about half way between the wheel hump and the rear of the frame. If the body is off you don't need a mirror. The stamping though is often very faint and hard to find, so be patient. Sometimes a light rubbing with sandpaper or a wire brush will help make the numerals pop out.
VIN location on 64 transmission Al T 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 07-11-2013 03:22 PM
VIN # on Frame orelog 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 05-09-2012 02:33 PM
65 frame serial # location? pbertrand65GTO 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 05-15-2011 06:18 PM
1970 "Judge" engine block VIN location question AllRise70 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 01-26-2011 10:50 PM
Frame Question (Boxing frame+) Fred007 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 20 12-13-2010 11:38 AM
