69 Gto Phs mistake? - Pontiac GTO Forum
post #1 of 8 (permalink) Old 12-11-2015, 09:43 AM Thread Starter
69 Gto Phs mistake?
i have a 69 gto restoration project. the vin on the phs and in the car seem to match but the dates on the cowl tag and the date on the phs do not match. is this common? also the car does have a ram air hood but on phs it did not have the ram air option. the car has never been wrecked and it appears the hood is original. it looks like the body has the original paint, so I don't see why the hood have been switched. and I don't know why it would have a ram air hood if it was not a ram air if it was the original hood which it appears to be. the motor is not original so I cannot verify it by that. I was wondering if since the dates did not match on the phs and cowl maybe it could be another mistake and it is a true ram air car?
also the car is for sale right now but id like to know about those things because id ask more if it was a ram air car
thanks
msnlewis is offline
post #2 of 8 (permalink) Old 12-11-2015, 09:54 AM
Can you post pictures of the data plate and vin tag rivets, also there should be a vin number stamped on the rear frame just behind or close to the driver's rear tire.
05GTO is offline
post #3 of 8 (permalink) Old 12-11-2015, 10:28 AM
Welcome to the forums!
post #4 of 8 (permalink) Old 12-11-2015, 12:35 PM Thread Starter
Here are the pictures I have right now I hope they are good enough
ID:	68338   Click image for larger version
msnlewis is offline
post #5 of 8 (permalink) Old 12-11-2015, 02:16 PM
What is the date on the PHS billing history, the data plate is showing the date as may 11-17, 1969?
05GTO is offline
post #6 of 8 (permalink) Old 12-11-2015, 02:23 PM Thread Starter
June 9th
msnlewis is offline
post #7 of 8 (permalink) Old 12-11-2015, 03:01 PM
Nothing strange about a Body build of 05C (3rd week of May) and a ship date of June 9th. Pontiac home plant had a Body Bank and the date spread could even be wider in '69.
On the hood, hoods got swapped through he '70's and '80's all the time. It also doesn't take much work to make a non RA hood into a RA hood. I can usually spot non factory hood tach installs, as on original '69 and 70 hoods that came originally with old tachs there is a spot that a pneumatic shear took a piece out of a brace in the hood.
post #8 of 8 (permalink) Old 12-11-2015, 03:26 PM Thread Starter
Okay thanks, i didn't think anything looked wrong but a potential buyer pointed it out to me and the sounded like try knew more about it than I did so I thought I'd see what other people out there though
msnlewis is offline
my mistake foreevergoat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 09-30-2014 09:20 AM
PHS Mistake? Colorado67GTO 1964-1974 Tempest, Lemans & GTO General Discussion 4 09-14-2014 08:32 AM
Dumb Mistake SC Goat 1964-1974 Tempest, Lemans & GTO General Discussion 3 10-21-2013 04:08 AM
Warpage mistake Logchain 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 7 07-27-2012 08:18 PM
I think getting the GTO was a mistake Taxman 2004-2006 GTO General Discussion 6 05-08-2006 02:23 PM
