69 LeMans block code question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 05-08-2017, 01:55 PM Thread Starter
I've been searching for an engine block code from a car I'm considering buying. The code I have doesn't seem to match any list of block codes that I can find. Here is the info:
It says 9749757 YU as far as I can tell. But I can't find that match anywhere. I know YU is a code they used so I'm assuming its the stock block but I don't know.
Any help is appreciated, thank you.
MikeKelso is offline
post #2 of 3 (permalink) Old 05-08-2017, 02:46 PM
The 69 lemans 350 YU should have a casting number of 9790079 which will be on the rear of the block behind the number 8 cylinder (passenger side). 9749757 above the letter code is the Engine Unit Number which may be listed on the PHS billing history.
Good luck,
05GTO is offline
post #3 of 3 (permalink) Old 05-08-2017, 05:47 PM Thread Starter
That's good to know, Thank you!
WW code RAIV Block g90g00huf 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 15 10-18-2011 07:57 PM
Block Code ID Mystery charlie4170 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 02-16-2010 07:57 AM
