Can't find my 1969 GTO's block VIN - Pontiac GTO Forum
post #1 of 12 (permalink) Old 07-23-2012, 09:44 PM Thread Starter
I traded my automatic '69 GTO with a numbers matching engine for another '69 GTO. I have not been able to locate the VIN on this engine block. It has the following codes: WT 0594408 on the front of the block, passenger side. On the back, passenger side, 9790071. The VIN on my pervious '69 was on the front, passenger side, near the timing cover in a vertical arrangement.
dkaufman is offline
post #2 of 12 (permalink) Old 07-23-2012, 10:42 PM
What's The date code by distributor?
post #3 of 12 (permalink) Old 07-24-2012, 01:47 PM
Quoted: 98 Post(s)
That casting number was used for 1968 and 1969. Both years should have the VIN where you described it. Strange......
post #4 of 12 (permalink) Old 07-24-2012, 04:17 PM
68GTO4004Spd's Avatar
It's not stamped very deep some of mine is barely visable. You might need to clean/wire brush and a strong light.
68GTO4004Spd is offline
post #5 of 12 (permalink) Old 07-25-2012, 11:42 AM
68greengoat's Avatar
Steel wool works good too. Given your info, it's one of these 2 motors. Only difference is the year.
WT A-body 68 400 350 4-speed L-67 1x4 9790071 2 GTO
WT A-body 69 400 350 4-speed L-67 1x4 9790071 2 GTO
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #6 of 12 (permalink) Old 07-25-2012, 01:13 PM Thread Starter
What is the best way to find the date code? I looked by the distributor, but I'm not exactly sure where I should be looking.
dkaufman is offline
post #7 of 12 (permalink) Old 07-25-2012, 01:17 PM Thread Starter
Looked around the distributor; didn't see a code. Possibly covered in grease? It seems like I will need to removed the air cleaner, then do some cleaning.
dkaufman is offline
post #8 of 12 (permalink) Old 07-25-2012, 01:23 PM
It's a cast (raised) 4 character code that will be one alphabetic character followed by 3 numeric characters. It will be on top of the block near the distributor hole. They can be tough to see with the engine in the car and the everything together. Sometimes using a strong light and a mirror helps. Here's a link to one example:
http://www.pontiacpower.net/pictures/blockdate01.jpg
The date code in this photo is B205, which indicates the block was cast on February 20th, 1965. In the photo the casting code (9778789) is also visible, so taking those two pieces of information lets us ID this block as a 1965 2-bolt main 389.
post #9 of 12 (permalink) Old 09-30-2012, 11:33 PM
This is my first time posting but have a similar question about matching VINs.
I have a 69 GTO and was wondering if the engine code on the front right side of the engine is suppose to match the last 6 of the vehicle VIN. It has a WT letter code, a 9790071 casting code and has a 1969 casting date that is before the build date. I believe it is from a 69 GTO just not sure if its the original motor that came with the car. Any help and suggestions would be greatly appreciated.
thegor is offline
post #10 of 12 (permalink) Old 10-01-2012, 08:18 AM
I have found it easiest to see the VIN from under the car...
It should look like this:
97ramsst is offline
Trying to find interchange info (1969 Custom S) celicaxx 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 08-29-2011 01:33 PM
Actual differences between and RA block and non RA block DrBoeing 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-26-2010 12:07 PM
Where to find GTO's? buckwheat_88 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 11-15-2004 02:14 PM
