Decoding 70' GTO Trim Tag - Pontiac GTO Forum
post #1 of 7 (permalink) Old 03-30-2014, 12:10 PM Thread Starter
I am considering a 70' GTO project and would like help decoding some of the info on the trim tag. I have attached a pic which hopefully you can read ok.
The 472B has me puzzled. Is the exterior code 47 Verdoro Green and the 2B an option or option group?
What do the following codes represent?
9B
CO8
Am I correct in assuming the M20 is in fact a close ratio 4 speed trans?
Thanks for any help you can offer!
gmjack is offline
post #2 of 7 (permalink) Old 03-30-2014, 12:26 PM
Quoted: 22 Post(s)
i believe 2B would be black vinyl top, not sure what the third line options are. Love the big Made In Canada stamping. Best bet will be to contact PHS.com and see if they have the original build sheet on the canadian cars, that will tell you exactly what options it was born with.
Instg8ter is online now
post #3 of 7 (permalink) Old 03-31-2014, 07:04 PM Thread Starter
Thanks again instg8ter...
I have determined the 472B is actually the exterior color 47 Verdoro Green...
The C08 is a full vinyl roof...
Now all I need is the 2B and 9B codes...
Would really appreciate any help with these codes...
gmjack is offline
post #4 of 7 (permalink) Old 03-31-2014, 07:29 PM
Quoted: 350 Post(s)
OK, just edited my former post.
Found this on the internet. The "2B" may be for the top choice/upper body. Are you sure the "C08" is for the vinyl roof? According to the website, those numbers that follow the 9B are the "daily production sequence numbers", "manifest sequence numbers", or "broadcast sequence numbers" depending on which plant built the car.. The 9B is the build date which is 9=September, B=Second week.
post #5 of 7 (permalink) Old 03-31-2014, 09:02 PM
Quoted: 22 Post(s)
yes the 47 is body color the 2B after it is black vinyl top
post #6 of 7 (permalink) Old 04-01-2014, 05:36 PM Thread Starter
I learned the C08 is definitely the RPO for a full vinyl roof. The 2B must indicate the Black color. Thanks for your help!
gmjack is offline
post #7 of 7 (permalink) Old 04-01-2014, 05:38 PM Thread Starter
Good to know Pontiac Jim...Thank you!
gmjack is offline
66 trim tag decoding rays66gto 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 9 03-29-2014 06:12 PM
Trim tag decode 1coolduck 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 0 08-25-2013 08:13 PM
Trim Tag Help Red1970GTO 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 10-06-2012 01:51 PM
Trim Tag Gold GTO 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 2 08-31-2010 07:55 PM
64 trim tag Help rare4k 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 10-10-2006 08:21 AM
