Engine Block VIN Location - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-07-2018, 11:44 PM Thread Starter
sitruc75's Avatar
Hello. I bought a 1969 GTO and was trying to locate the VIN on the block. I know where the VIN should be but it is not there. I found what I believe is the VIN stamped but it's in an odd place. It is beside the block code. Has anyone ever seen this before? I will attach pics of the actual VIN and where it should be stamped. I will also attach pics of where I found it.
ID:	113401   Click image for larger version
ID:	113409   Click image for larger version
sitruc75 is offline
post #2 of 5 (permalink) Old 06-08-2018, 06:08 AM
Would be a real oddity, if not a tipoff to a restamped Pontiac block, to find the Fremont plant stamped confidential VIN up & down next to the timing cover like blocks stamped (late '68 and later) out of other assembly plants.
Fremont typically stamped up high, often just a little lower than what you are showing and at an angle. Many times the gangstamp tool was quickly held and struck at an angle and the last few numbers will trail off, very hard to discern what they are. The original "70 and '71 Fremont stamped Pontiac blocks I have also used a different size font than did the home Pontiac plant.
post #3 of 5 (permalink) Old 06-08-2018, 10:06 AM
Limelight's Avatar
Cool, I didnt know that.
“That's one small step for man, one giant leap for mankind”
Limelight is online now
post #4 of 5 (permalink) Old 06-10-2018, 06:44 PM
I bought a 1969 GTO recently and had the same issue finding the code to authentcate the claim of numbers matching. I can only find the YS code a and no numbers. I have looked everywhere I can see without taking parts off the engine. Very poorly kept engine compartment. Someone told me a few weeks ago to look behind the lower radiator hose but it went there either. Is there anywhere else I can look? I am not sure where the pics you showed are on the engine. Was one near the water pump?
Jim.
JIM
Jlombardi is offline
post #5 of 5 (permalink) Old 06-10-2018, 07:41 PM Thread Starter
sitruc75's Avatar
I will attach 2 pictures. The first pic is where the block code WT is located as it should be. The second is where I found the VIN stamped. I used some paint stripper and a toothbrush to remove some of the paint on the block.
ID:	113545   Click image for larger version
sitruc75 is offline
1968 Engine Block VIN stamping GTO-1969 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 01-28-2018 04:49 PM
Vin location bills65 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 5 04-18-2015 09:33 AM
69 Frame VIN location-Where is it. GTOALAN 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 09-20-2013 09:54 PM
VIN location on 64 transmission Al T 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 07-11-2013 03:22 PM
1970 "Judge" engine block VIN location question AllRise70 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 1 01-26-2011 10:50 PM
