Engine code for 1965 GTO - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-28-2016, 08:40 AM Thread Starter
I have found conflicting info on web sites as to correct engine number. Some show WE and some show WT. Which is correct?? This is a barn find. Sat in a barn totally disassembled for last 20 years. No rust, totally straight.
Can someone give me the correct engine code?
Thanks.
bonneville604 is offline
post #2 of 3 (permalink) Old 01-28-2016, 08:54 AM
WT is correct 3spd/4 spd manual trans code for '65 GTO 389 4 bbl. The WT code was used for both '65 and '66 389 4 bbl manual trans GTO engines, and the WT code was used as the base 400 4bbl manual trans engine code from '67-70. Always smart to ck the casting number and casting date on the block to see what one has, many many blocks have been swapped out over th years.
On the YE code block, that was a very common 389 and 400 block hrough the late '60's. The most desirable YE blocks were 4 bolt main 455HO auto blocks used in '71's and 72. Easy to spot, as all used the '71-74 style of assembly number stamping where the 6 digit assembly number begins with a (
post #3 of 3 (permalink) Old 01-28-2016, 11:12 AM
rickm's Avatar
Quoted: 5 Post(s)
WS WT YR or YS.
rickm is offline
1965 Gto data plates code and engine date alsgto 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 12-06-2009 05:16 PM
1965 Engine date Code ? 69classic 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 11-14-2009 12:30 PM
1965 gto paint code ? cruzingratiot 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 9 02-28-2009 12:45 PM
Intake Manifold Paint Code 1965 GTO pjshortt 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 5 01-28-2009 02:59 PM
