Engine Code Numbers V8's - Pontiac GTO Forum
post #1 of 2 (permalink) Old 07-06-2013, 04:19 PM Thread Starter
Hello all,
I just rescued two old V-8's. One I have pretty much ID'd except there's diff info regarding valve sizes. It is a 1971 400 2bbl 481988 with number 99 heads, date code F-11-1. Sources say one 99 has 1.96/1.66 and another says 2.11/1.77. Has anyone verified by physically looking which is correct for the 99 heads?
The other V8 is a 1963 389 4bbl with 543797 heads, 9770274 intake, 9773771timing cover and on the block pad are stamped these numbers/letters; 023527above 36P, to the left stamped in are 863P above 6493. The data states a 303hp 389 out of a B body car. The timing cvr numbers are for 64-65 and data shows the engine numbers should be 538181 or 543680, date code is I-12-2. Thanks TomL
Tom L is offline
post #2 of 2 (permalink) Old 08-01-2013, 08:46 PM
re. engine codes
I have the same 71 engine as yours. Recently pulled the 99 code heads and unfortunately they have the smaller 1.96 1.66 valves. I read the same two conflicting infos as yourself.
Now im trying to purchase a set of 16 code heads ive seen for sale as im under the impression from reading on this forum that I'd be wasting my time trying to build a decent HP engine whilst choking it with the smaller heads.
Hope this helps
cheers
Geeza71 is offline
Engine code I.D Bighorn Fool Service, Maintenance and Technical Discussion 2 03-12-2013 04:24 PM
help identify engine with these numbers OrbitOrange 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 4 01-26-2012 11:49 PM
Help...engine numbers ? 55gasser 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 3 11-09-2011 08:30 PM
Where to find engine numbers? Artemis Entreri 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 5 04-30-2010 06:21 PM
need a little engine code help excessive 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 06-03-2009 07:17 PM
