Engine Swap advice All numbers matching car - Pontiac GTO Forum
post #1 of 12 (permalink) Old 01-20-2010, 09:34 PM Thread Starter
Ok here is my delima. I have a 1966 Tempest. It has the in line 6 OHC engine. The car is all original with the exception of the grill inserts.
I would like to put a bigger motor in it before i get it painted. Nothing extreme maybe a 350 or small block 400. Everyone keeps telling me keep the original motor in the car or at least keep it for later.
Not my thing......... I would never be able to the motor if it is not in the car.
What is your thoughts on the engine swap?
Also what kind of "MODS" have to be done to put a chevy motor in a tempest?
Your input is valued
Harry
Dirty Deeds is offline
post #2 of 12 (permalink) Old 01-20-2010, 10:36 PM
66tempestGT's Avatar
i put a 327 chevy in my 66 tempest. chevelle engine mounts bolt directly to the tempest crossmember. i never knew why, but it seemed that the engine tilted very slightly to one side. may have just been the beer. im not familiar with the six but the chevy has the starter and fuel pump on opposite sides from the poncho V-8. the battery will be on the wrong side and you will need a longer +cable. the fuel lines will come from the wrong side of the frame and need to be extended.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #3 of 12 (permalink) Old 01-21-2010, 07:39 AM
The transmission is also different and will need to be replaced with the chevy engine.
You could drop in a Pontiac 326, 350, 400, 455 motor with less changing around.
post #4 of 12 (permalink) Old 01-21-2010, 12:01 PM
Quoted: 98 Post(s)
V8's are a dime a dozen. OHC 6 cars are rarely seen. I would sell the car to someone who appreciates what it is and get a v8 car. That way, history is preserved and you will be happy. Also, a lot less work involved.
post #5 of 12 (permalink) Old 01-21-2010, 08:20 PM Thread Starter
Will the transmisson mount to a Pontiac engine?
post #6 of 12 (permalink) Old 01-21-2010, 08:29 PM
Yes, Pontiac, Olds and Buick have the same tranny to engine bolt pattern, chevy is on it's own so that's why the tranny would need to be changed. Some tranny's do have both bolt patterns but if your tranny is original, it won't. And if you do do this V8 conversion, please keep the 6cyl motor for future sale of the car. Pickle the motor before you pull it out so it will survive long term storage by running the engine at about 2500rpm and choke it out by pouring AFT into the carb opening until the motor dies out. That will coat all the internals and keep everything lubed and safe as long as the motor is wrapped up tight or kept indoors.
post #7 of 12 (permalink) Old 02-01-2010, 07:14 PM Thread Starter
My question is this.
What motors Size 350 to 455 with tranny can i put directly into the same motor and transmission mounts and wiring as the inline 6.
I hae found several "Donor" cars that have verious engines in then that i can yank out and put in the tempest just not sure what will mount wth the lease ammount of altering of the car itself. I know of a 69K mile olds that has a 455 Rocket and three speed tansmission it it that i can get for 800.00 but im not sure what i will have to go through to make it fit in the car and run.
Thanks Harry
post #8 of 12 (permalink) Old 02-01-2010, 07:53 PM
i dont have any idea what is involved, but i like the way you think!
Shane Doss
66 tempest
64 el camino
02 mullis dragster
post #9 of 12 (permalink) Old 02-01-2010, 08:42 PM
Pontiac V-8s should bolt right in. Which ever engine you choose will need ALL the brackets and belts for the components on the front of the engine. You may also need the radiator and shroud. Exhaust of course will be different. Not sure if an Olds will bolt into the frame or not, but if not, you could always pull the stands off the frame from the donor car.
I wouldn't expect any engine to fit your old wire harness. Label the wires for the temp sensor, oil pressure switch, coil, alternator, etc and then shorten or lengthen the wires as need to the replacement engine.
post #10 of 12 (permalink) Old 02-02-2010, 06:18 AM Thread Starter
Awesome thanks for the good news....
Now i either have to find a place to store this engine or someone that needs it.
Thanks Harry
How rare is a numbers matching car? F-RICE 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 17 07-26-2009 07:27 AM
Not Numbers Matching texaz 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 17 06-03-2009 06:05 PM
matching numbers bamm 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 10 01-16-2009 11:39 AM
NUMBERS MATCHING on a 1965 ? bigeasy 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 4 07-14-2008 09:17 AM
